Best Header Gaskets??
Old Oct 2, 2008 | 06:18 PM
Cody Ashby's Avatar
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
Just like the title says boys..im lookin for the best header gaskets for my hedman full lengths..the cheap ones that came with it have already went bad! thanks
Old Oct 2, 2008 | 06:55 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Best Header Gaskets??
how do u mean went bad??? my driver side went bad like a week after i put it on bc the flange is not flat at all lol... kinda bummed me out but my passanger has been on for 2 yrs with no probs. i just ordered a new set of the stockers for my headman LT's... the same ones (white ones) that come with the headers bc they are cheap. u need to figure out if your flanges are warped bc mine is and thats why it went bad. before u start throwing gaskets at it.
BY FAR! the best gaskets are the dead soft aluminum ones... a couple of companies make them.they are thick and they are soft, but the cost alil bit... but usually seal just about anything bc they are so thick and soft. still i would try and fix that flange first. if its bad enough the dead soft aluminum gaskets might not even seal that.
Old Oct 2, 2008 | 09:42 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
i will look into that..thanks you so much!!
Old Oct 4, 2008 | 11:34 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Dead soft gaskets, either aluminum and or copper are the best out there. However, simple multi layered composite gaskets will work just fine. I only use the thick "dead soft" gaskets when I suspect a flatness issue with the header flange.
Old Oct 6, 2008 | 04:37 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Any idea who sells "dead soft metal gaskets"??
Old Oct 6, 2008 | 05:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Percy's has some nice sets and I believe Mr Gasket makes a set now too.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
