bolt on headers
Old Oct 10, 2008 | 11:29 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
bolt on headers
ok i know there are tons of threads about headers but i couldnt find one that talked about direct bolt in headers that i can buy and put in the car with no modification or welding are they even made?
Old Oct 11, 2008 | 12:55 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You have to get an emissions-legal set that has a y-pipe. Edelbrock TES p/n 68743 fits the bill.
Old Oct 11, 2008 | 01:01 AM
Engine: L69 H.O
Re: bolt on headers
alright thanks
Old Oct 11, 2008 | 01:07 AM
five7kid's Avatar
I was doing a lot of editing, not sure if you saw my final answer.
There are other headers available, but the TES are the only ones that would bolt in. You'd still have to modify the AC bracket (cut a leg off - not a big deal).
Old Oct 11, 2008 | 01:16 AM
Engine: L69 H.O
Re: bolt on headers
there is no way to get them in without cutting the bracket the reason i ask is because i dont want to do anything to my car that cant be reversed incase i want to put it back stock
Old Oct 11, 2008 | 01:43 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: bolt on headers
You can always get another bracket.
Old Oct 11, 2008 | 01:50 AM
Engine: L69 H.O
Re: bolt on headers
yeah i was just seeing if it was really needed thanks for the replies
Old Oct 11, 2008 | 11:29 AM
five7kid's Avatar
If you don't have it, the compressor will shake around and break other things. It's fine with the one leg cut off.
Somebody sells, or used to sell, a bracket that's already been modified. I can't locate it at the moment, though.
Old Oct 11, 2008 | 02:44 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Re: bolt on headers
Hooker makes the bracket. Its on summit.
Old Oct 11, 2008 | 03:00 PM
Engine: L69 H.O
Re: bolt on headers
thanks for the info guys i will be buying these headers and bracket with my next check do they have a spot for the o2 sensor also do they come with gaskets and if not what should i get
Old Oct 11, 2008 | 05:13 PM
five7kid's Avatar
They have the O2 sensor port, and come with gaskets.
Old Oct 11, 2008 | 10:42 PM
Engine: L69 H.O
Re: bolt on headers
alright thanks for the help
Old Oct 12, 2008 | 02:33 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: bolt on headers
Edelbrocks the only header he can use with AIR and y-pipe?I was sure thier were others or is it another reason why you`re recomending tes.I thought they were one of the poorer headers we could get for our cars.Just asking.
Old Oct 12, 2008 | 11:34 AM
five7kid's Avatar
They are the only ones with a y-pipe that will bolt directly to the stock cat. Bolt-in was the driving criteria. The "Y" joint itself is a little weird, but overall they're a good improvement over stock manifolds and y-pipe.
tom1985
Apr 19, 2016 07:55 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
