Custom side exhaust!
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
At least the dude thought so.Was at the junkyard yesterday & saw this.Cant believe what some people will do to their vehicles.Guess its suppose to be dual outlets.Maybe one fell off!
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Re: Custom side exhaust!
wonder if you could somehow make it so there was a functional exhaust coming out of the gfx just after the front tire....
Dang it I really need to get another Fbody just do to stuff like that with. I dont wanna change the exterior of my SC too much, and the car would need GFX to make it look right I think.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
i have a side true dual exhaust on my iroc...long tubes and two pipes right infront of the rear tire under the grx tho...not through it....works good as a leaf blower when you drive down the block....but that...thats jus a hack job....
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
I always though about this idea like how the roush mustang has it. I always thought it will look dope on our cars.
Tony.
Tony.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
That's the general idea for the way I want to eventually route my exhaust. You'd have to route the pipes over the LCA mount and possibly threw the cabin.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i would imagine that the heat from the exhaust being shorter it will be hotter, would warp/melt or discolor the ground effects. i wanted to run side outlets for my true dual but i had interference with the LCA movement. the onlyway would be to run the exhaust right along side the perimeter of the sill and have a short 45 degree at the end.
if i wasnt worried about the work i would cut the door sills out and weld in thicker boxed steel and run the exhaust in it or use thick large 90 degree steel and just rebuild the sill area for more clearance... basically killing 2 birds with one stone. clearance for side exhaust and SFC essentially.
ive seen this type of work on some mustangs that run around lol... ends up having black from the exhaust all around the backside of the hole lol due to exhaust carbon. u prob see it all the time on ricers and fart can mufflers.
Engine: 3.0L 2JZGE
Tony.
Car: 87 GTA
Putting an oval tip(s) just under the ground fx is nothing new, but THROUGH the fx would be better, but much trickier. On a 4th gen, I've seen the fx notched to tuck the tips up about 3/4 way up into them but never fully through.
Engine: 3.0L 2JZGE
I like it how the first pic has it. It would be cool on both side.
Tony.
Tony.
Engine: 3.0L 2JZGE
I'm going to do a side exhaust setup when I have the engine back in the car, I did some checking and it looks like with some home built/designed subframe connectors I can tuck the entire exhaust away much higher than in that 1st pic and have a wide but shallow end sticking out under the GFX for max. ground clearance. I'll do a duel exhaust 1 side exit.
Car: 87 GTA
I hope your talking about both tips on just the passenger side. Besides true duals (1 on each side) not being legal anywhere, California DEFINATELY won't let you slide by at inspection time!
Engine: 3.0L 2JZGE
Tony.
Car: 1986 IROC-Z
Engine: 305 Q-jet
Reading all this side exhaust stuff i had the weirdest idea come to my mind, what can u guys tell me about trying to put the same well almost the same set up an SLR Mercedes McLaren (pipes coming out from behind the front tires) on a third gen? any ideas on how would it perform? or how to do it.
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
