sfc's in the way will this work?
Old Oct 16, 2008 | 05:10 PM
chaoz28's Avatar
Car: 87 formula/69 beetle
Engine: 355/2.1
Transmission: T.C.I streetfighter th350/5 speed
Axle/Gears: 3.73 lsd/
i just got a set of umi performance sfc's for my 87 bird and the system i have is in the way and i was wondering if it would be a problem to run a system like this but fitted to my car
http://www.umiperformance.com/images/2205l.jpg
Old Oct 17, 2008 | 09:07 AM
UMI Performance's Avatar
Re: sfc's in the way will this work?
If you run a true dual system like in the picture you should have no clearance issues at all with our SFC's
If I can help anymore please let me know.. .thank you!
Ryan
Old Oct 17, 2008 | 11:17 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
check out the true duals sticky at the top. It should really only be a problem if you're lowered or really worried about ground clearance. I ran true duals with turn downs on my daily driver for over a year with the only problem being scraping going into really steep driveways. be forewarned though a set up like that will be loud.
Old Oct 17, 2008 | 02:07 PM
chaoz28's Avatar
Engine: 355/2.1
thanks for the help ground clearence is not a problem my car is stock height. and as far as loud thats kinda exactly what im going for my city has a muffler rule but there is no decible requirement if i can afford this syetm now that i know it works ill use a pair of dynamax round mufflers
Old Oct 17, 2008 | 02:34 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
from what i understand even at factory ride height, there are ground clearance issues if the system doesn't tuck up pretty well. But hell look at the ls1 cars, they run true duals all the time on dd and not a bad word and i don't think the fourth gens are too much higher than our cars. just some food for thought.
Old Oct 17, 2008 | 02:38 PM
chaoz28's Avatar
Engine: 355/2.1
well aside from curbs and speed bumps. cruising the streets shouldnt be a problem should it? im going to have it sit as close to the bottom of the car as possible but im putting 3 inch on it all the way plus the dynamax race mufflers are about 4 around.. i dont wanna send sparks on every dip
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
