v6 header question
Old Nov 3, 2008 | 04:32 PM
crazyjugglers2's Avatar
v6 header question
hi, i have a 1992 rs with a 3.1 v6 and a 5-speed, my problem is i am trying to find headers for it but i have so far been very unsuccessful. I saw that pacesetter makes headers for the 2.8, 3.4, and 3.8, but unfortunatly didnt see any for my 3.1. Does anyone know where there is a decent set for my 3.1? Or if maybe the 3.4 headers will fit on the 3.1 engine? thanks i appreciate it
Old Nov 3, 2008 | 05:44 PM
91camaro372's Avatar
Car: 91 Camaro RS
Engine: 3.1L v6
Axle/Gears: 2.73(for now) posi disc from 95 Z28
Re: v6 header question
The pacesetter headers for the 2.8 should work fine.
Old Nov 6, 2008 | 10:56 AM
Pocket's Avatar
Car: 91 Trans Am
Much like 305, 327, 350, 400 SBC's
60* V6s have the same externals
2.8, 3.1, 3.4
That means exhaust will interchange
3.8 is a different animal and the headers will not fit
Old Nov 6, 2008 | 02:58 PM
2.8, 3.1, 3.4
thanks very much, i appreciate it because obviously to go out and spend a couple hundred dollars on the part would be a complete waste. thanks again
Old Nov 8, 2008 | 07:53 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you have the AIR pipe in the passenger's side manifold, forget it. You won't find headers with the AIR bung...
Old Nov 11, 2008 | 08:49 AM
Pocket's Avatar
Car: 91 Trans Am
Actually you can order the pacesetters with or without the AIR tubes
Not like the AIR system is that difficult to delete anyways
Alot of factory cars even had the delete pulley
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
