Headers
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Headers
Hooker also makes a good set, with bigger tubes too (1-3/4"). They are a tighter fit though.
Car: 86 Z28
Axle/Gears: 3.42 posi
Re: Headers
aren't those the $500 ones, the hedman ones are $150. I don't have much money to spend on these so i was thinking the hedmans or the hooker shortys. how far would the hedman headers stick down? would there be enough clearance for speed bumps and stuff?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Headers
If you dont have the money to buy the headers do you have the money to install them? Long tube headers are NOT a direct bolt in. They require a lot of trial and error to fit them in, plus you have to pay a muffler shop to build you a custom y-pipe to connect them to the rest of your exhaust.
If $150 is your budget then I suggest you keep saving until you have $1000. A good set of headers plus y-pipe plus installation will cost you about that much. Look into the Hooker 2055's. They are shorties that come with a good y-pipe and will be easier to connect to your existing exhaust. They're also smog-legal.
Did you read my sticky post "What's the best exhaust? What are the best headers?" at the top of this thread?
Car: 89 camaro
Engine: tbi 350
Transmission: th400
Axle/Gears: 10 bolt 3.73 posi
Re: Headers
hey i have a 1989 camaro with a tbi 350 and i was told i cant put long tube headers on it but ive seen it done is there certain ones i would need because i have a set of new heddman long tubes that i would like to use.
some tips would be great.
Car: 86 Z28
Re: Headers
i see that flowtech makes shorties and a y pipe each for $119, are these worth getting. I would install them myself to save money.
Car: 86 Z28
Re: Headers
how would the flowtech be to install would i have to trim the ac and ps brackets? and I don't need air tubes cause i'm going to remove the restrictive cat.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Headers
You can use them they just don't have air tubes like your original exhaust manifolds. they bolt up no problem
Last edited by FueledSoul; Nov 10, 2008 at 09:57 PM. Reason: Automerged Doublepost
Re: Headers
Heres somethings your going to run into with the hedman long tubes https://www.thirdgen.org/forums/exha...tml?highlight=
Last edited by FueledSoul; Nov 10, 2008 at 10:13 PM. Reason: Automerged Doublepost
Re: Headers
I hope you're removing the restrictive stock cat and replacing it with an aftermarket "high-flow" cat such as from Magnaflow, Catco, or Random Technology. Otherwise you're just polluting the air.
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Headers
Kevin, I did read the sticky post but didn't see anybody complaining about the Edelbrock TES headers other than you. You stated that they're the worst design in your opinion (or words to that effect). I'll respect that, but what is it about the headers? They're all a pretty tight fit, so that shouldn't be the reason, are they poor quality? what is it? The "Y" pipe? What is it about the "Y" pipe? Have you ever used a set? After reading about the Edelbrock TES headers I deceided that for the price they're the right header for me. They're the only ceramic coated headers that I found that had a "Y" pipe that fit directly to my 4-bolt cat. They were $489.00 shipped (3 day shipping) to my door, so price was a major factor. I hope I have good things to report back.
Car: 86 Z28
Re: Headers
cats are overrated... I think I will put the hooker comp. shorties(2460) on if i put headers on, and make a true dual that dumps out behind the doors.
Transmission: 4L80E/4L80E
Edelbrock does support more configurations than anyone else, I'll give them that. But, that "Ti-Tech" isn't ceramic coating, either.
Cats aren't over-rated, but deleting them is.
Car: 1983 Trans Am
Axle/Gears: Stock
Re: Headers
We just installed a set of headman headers shortys on my 83 TA,
uses a flowmaster muffler that came in a kit. It was around $700.00,
but well worth it.
but well worth it.
Re: Headers
I got these from Jegs. I ordered them online at 10:00 Wednsday night. They were sitting on my doorstep this morning (Friday) at 11:30 AM... I think the shipping was $12.00 They FedEx'ed them out that night. Incredible.
Was there a point where you thought they might not fit your cat?
Last edited by Kevin84Z28; Nov 15, 2008 at 01:05 AM. Reason: Automerged Doublepost
Re: Headers
I just finished pulling off the old exhaust manifolds...Took 4 hours to get it torn down and cleaned up. I only skipped one step and that was pulling apart the steering shaft. I just couldn't see an easy way to do it. But luckily I just wiggled the header past the shaft with a little muscle and they slipped past. Oh, and I also broke one spark plug. No biggie.
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
Re: Headers
Remember if you have a manual tranny t-5 lol a lot of long tubes wont fit! Hooker 2210s are the ones i found but they are 500+ bucks and DONT come with anything else.
redformula88
Oct 14, 2015 06:08 PM
