Help On My Choice Please?
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I have a 1989 Camaro RS and looking for a new exhaust.
It sounds like Flowmaster has what i need, the loud and aggressive sounding exhaust the series 80 i believe. But i heard negative comments on them as they would heat up and melt the paint of the side of the car and other problems.
I was wondering if anyone would help me on a decission of what i'm looking for.
I want loud and aggressive sounding exhaust. I need cat back and catalyic converter as well. Anyone price me on what i'm looking for?
regards,
Timinsk
regards,
Timinsk
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Help On My Choice Please?
Did you see my sticky at the top of this forum? "Whats the best exhaust? What are the best headers?"
Magnaflow sounds great in my opinion, is a much better design than Flowmaster, and you can buy their catalytic converters, too.
If you search youtube.com for "kevin91z28" videos you can hear my car, too.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Are Magnaflows reasonably priced?
Do you have any videos on what it sounds like when driving?
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
[bump]
Anyone to answer my question?
!!!EDIT!!!
Ignore what I just said; I did check on the website and I got this brought up:
Click On Part# For A Detailed Description.YearDescriptionPart #MSRP1989V8 5.0L
5 x 8 x 18in. Dual Outlet Muffler, 3in. System, Dual 3.5in. Polished Tips, DUAL REAR EXIT16829$561.41 1989V8 5.7L
I don't have the 5.7L I have a 5.0 But does it really matter? I'm looking into longer down the road with a 350 or 383 or 454 from GM but just saying though is it worth just getting the "5.7" exhaust even though they have the same description?
Anyone else experience these products from Magnaflow? Are they safe? Sturdy? Loud & Aggresive sounding? Is it worth it? I just want to make sure before I waste my money!
!!!EDIT!!!
Yes you can use the same exhaust for a 5.7L or a 5.0L, especially if you're considering upgrading later.
Magnaflow is a good company, they make good products and their mufflers sound great in my opinion.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Thanks that helps and how about the catalytic converter? I notice they have a 5.0 and 5.7; should i go with 5.7 or would it not work on my engine? Because i think im doing the catalytic converter first then later save up for the 5.7 exhaust..
Transmission: 4L80E/4L80E
1987-1990 TPI single cat exhaust was the same for 305 and 350. So, it's not a 305 vs. 350 thing, it's TPI vs. TBI.
Just get the 3" stuff.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
http://www.car-sound.com/02product/d...irectfit=93456
vs
http://www.car-sound.com/02product/d...irectfit=93441
I notice magnaflow with their cataylic converters have a universal fit and a direct fit. I thought it might be easier and more efficent with a direct fit but i may be wrong. Theres a big difference in price though. I'm a little out of order when I look at their list of parts from the 5.0 and 5.7, i know the E is for my car because thats the tbi i believe. I'm just curious on what I should get for that. I alittle more help please? I'm sorry for extending this i just dont want to really screw up to badly..
Direct-fit has the flanges on it that would bolt to your stock exhaust.
Get the universal fit and have your local muffler shop weld it in. Since you're changing from the smaller 2 1/4" cat to the larger 3" cat, you cant use the direct-fit.
Part number 94019.
Part number 94019.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
!!!EDIT!!!
I noticed in the sound clip they provided they state "dual catalytic". Is that better or make it sound more aggressive?
http://www.magnaflow.com/04sound/dom.../90camaro.html
Probably not. The welding is going to cost you more than the difference in cost between the cats.
If you're getting everything from the cat and on back, if you get direct-fit TPI pieces, the only modification will be from the y-pipe outlet to the cat inlet.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
What would you recommend? I havea tbi by the way. Which would be cheaper and better?
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Car: 85 Z28
Transmission: 5 speed
I think I am gona go with these guys.....
http://www.mufflex-performance.com/
Car: 1992 rs
I just put a Pypes Violator Muffler on my car( edelbrock pipes) , and it sounds GREAT!!!!!!! Mostly for stangs, but sounds good on my car ( 305 carb with some mods) . Look it up on u-tube
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
nice i just want to get it my first shot though with what i want to pick.. the system is a bit expensive i cant just be buying like 6 different kinds to try :P though i soooo wish i had the money too Joined: Mar 2000
Give them the cat-back and cat (some shops won't install customer-provided cats, so be aware of that), they can cut out the old stuff, bolt in the new stuff and adapt your y-pipe to the cat inlet, for less than having them fabricate a bunch of stuff.
If they won't install a cat you bring into them, they'll probably charge double for the cat itself - so, you'll have to have them price that out to determine if universal or direct-fit is a better deal.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
If you get a cat-back, it can be bolted on - no welding required.
I have been assuming you'd be using your stock y-pipe.
No, what I'm talking about doesn't come with a y-pipe. Some headers do. But, I was under the impression you were looking for loud more than anything else (the opposite of what I would be looking for, but to each his own).
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
but like you said "but to each his own." so what do you think? Senior Member
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Hey man i love my 80 series! i wouldnt mind if they were a little louder its cool. You can hear mine on youtube if u want. Type in drifting with the beast it just me messin around a little in a parking lot but u car really hear them at the beging.
kevin
kevin
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Also i heard problems from their cat backs from flowmaster that it heats up really highly and it gets at your paint and much more under the body than others do.. thats why i was scared at first to purchase
!!!EDIT!!!
Normally its just the whole comment: "one question" but its more like 2..
1. Could I borrow your rims and tires?
2. Would I need a body brace for my car to not fall apart from that? lol
Man dude i dont have that problem but with mine i have huge tail pipes. They are like 2 ft long 3 1/2 ins wide and they dont get real hot. And i wonder y youtube isent working?
kevin
kevin
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
ct is so packed there isn't like some huge acres of parking lot sadly..
but i might stick with magnaflow they seem really loud
thanks for your thoughts and experience! Supreme Member
Car: 1990
Axle/Gears: stock
i like the headman 2055 with a borla exhaust. but borla is expensive so you have to crawl over the net to get a good price. they can be gotten for about 400.00 but you have to really look.
you can adjust the noise level anytime you want.
gixxer92
May 18, 2017 11:20 AM
david068513
Sep 18, 2015 10:36 AM
