I need a less expensive idea...
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
I cant afford to go with DD or hooker headers since I think my dad might get them for me for x-mas but I need to go cheaper. I dont need emission testing and Im gutting my cat too. Im only looking into putting a est of 300hp in the next 1-2 years. What are the best headers for around $300-$350?
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: I need a less expensive idea...
http://www.jegs.com/i/Hedman/500/68460/10002/-1
i have those, they take some work to get in, you DONT have to lift the motor or anything crazy, just trim the a-arm and maybe a small dent in one primary to clear the driver side kmember. you have to have a custom y pipe made though, my exhaust shop built me a nice one for 150, it is crushbent, BUT it works just fine for my motor
Transmission: 700r
I can go a little bit more in price. I want to buy the parts and install. Im trying to avoid custom weldings
Transmission: 4L80E/4L80E
HP/$, you aren't going to do better than Hooker 2055HKR. No welding required.
Or Dyno Don.
You try to cheap out up front, you're going to spend more or get less in the end. There's just no getting around it.
Or Dyno Don.
Transmission: 700r
im only building my car up to around 300-350hp in the next two years though
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
i also use the hedman lt's. they worked great on my 358" smallblock with about 450hp. mine fit great..the only issue is the collector exit area makes ypipe and xpipe fabricating a chore. just my $.02
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
If i was you i would spend the extra money and get the 2055s, i dont feel like cutting and welding my a-arms or k-member,
You could try those stainless steel headers that guy on ebay sells, lots of fitment issues i bet though. My .02$
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
i have hedman elite shorties and they sound great, my only issue is the y pipe is giving me a hassle to install. The headers are thermal coated and use a ball and socket flange. i think that there in your price range but i dont know to many people that are using these headers
Transmission: 700r
Thanks,
Kevin
Car: 1990
Axle/Gears: stock
does anyone know where i can get some afterparket ball and socket flanges so that i can prefab the cat hookup. i have the 2055's and want to get it ready for a 3" y pipe into a 3" cat. i dont want to be running the car all over LA to get it welded, so i want to ball and socket flange it, unless there is a better way. but i DONT WANT TO WELD A 3 HOLE FLANGE ON IT, the darn flange never fits right if you do it off the body. it either hits the heat shield or the lower flange rubs on the ground.
any ideas?
any ideas?
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
I got lucky with a pair of Edelbrocks fitting right but that is the exception not the rule. Everyone says the Hookers are the best for the money.
Transmission: 700r
Yea I can tell but $450+ for headers and more for installation is not in the picture. I dont care how hard it is to put on because im not doing it
Ease of installation may not seem important if you aren't doing the work yourself, but the easier it is, the less it will cost to have them installed.
You might be able to find headers that are lower priced, but you won't find a better overall value than what we've been telling you.
Transmission: 700r
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Wanting new or used ? Im sure you could find something to your liking in the classified section.
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
Hedman elite headers
Yea the only problem i have is installing the y-pipe, im still working on it. Its 2, 2 1/5 pipes to a 2 1/5 collector with a 3'' expander. other than that there great
You can get less than you paid for, but it isn't reasonable to expect to get more by paying less.
Transmission: 700r
That still doesn't mean the quality of the final product won't be affected. Get a cheap set of $149 headers that have to have the stock y-pipe modified to fit to them, do you really think he's going to make an all-new y-pipe with mandrel bends for $50? On the other hand, installing a set of 2055HKR with its great y-pipe would be less work for him, and you'd have a better system when it's done.
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
WhteRbt
Sep 21, 2015 09:48 AM
LiquidBlue
Sep 13, 2015 02:24 PM
