Band Type Clamps
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Band Type Clamps
I bought a few Walker Mega Clamps (listed by Summit as Dynomax brand) and I have a question for those of you that have used this type and brand of clamp.
Both 3" and 2.25" clamps I bought come with a length of caulk (dum-dum) attached to the clamp. What the heck is this for? Do I use the clamp with it or remove and pitch it?
I've contacted Walker, but I haven't heard back from them yet.
Re: Band Type Clamps
That is a bit of sealer that's to be placed where the two halves of the clamp come together. There's a small gap that remains once the clamp is installed and this seals the gap.
Don't forget to use the proper torque specs on the bolts. They take a fair amount of tightening (mine was 60 ft/lbs) to seal completely.
Car: '87 IROC
Engine: LB9
Here's Walker's response. No real how and/or why detail.
Thank you for your inquiry for Walker Exhaust. We appreciate your interest
in our products. The sticky substance is just a secondary sealant that
will assist in getting a tight seal with the clamp, so you will wish to
leave it in place.
If you have any further questions, please feel free to contact our tech
line at the number below.
Thank You,
Lisa Kortz
Lisa Kortz
Walker Exhaust
Installation Technician
Tech Line Number
1-734-384-7830
For a dealer near you, please log onto our web site www.walkerexhaust.com
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i used those clamps on my last exhaust, all 3" and 1 2.5" one, i will never buy or use them again. They didnt hold the pipe tight enough, and after time with vibrations and heat cycles, they loosed their grip and my tail pipes would rotate, and my over axle pipe fell apart on me. I had to go around and shoot screws through them all to hold the pipes together.
Car: Pair of 92 Z28s
I've used them. It's normally hit or miss. Sometimes ive had them seal and stay tight others no so well. Some have stripped out the bolt holes from tightening too much also. If it doesn't seal with these it needs a flanged joint or weld in my opinion.
So far I've had excellent results. I also like the ability to take the pipes apart without having to cut things up. I found the torque value was very important. I used a torque wrench and then redid them after the first few heat cycles like header bolts.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I wouldn't say mine had a 100% seal, but running a boosted motor making probably 850fwhp through one 3" pipe doesn't help. I made some tabs for the clamp bolts to grab onto to stop the connections blowing apart. All and all, I like them.
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
thats a sweet lookin exhaust looks really clean is is custom?
Yes. TIG welded stainless with modified header collectors. I've designed it so that I can drop it at the drag strip and add collector exenstions. No results yet with the exhaust removed because I keep breaking transmissions and differentials. I hope for better luck this season.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I had no luck with the Walkers or Dynomax when doing my exhaust. I tried these: http://www.jegs.com/i/JEGS/555/30733/10002/-1 and they worked great. Sealed the 1st time, and have been fine ever since.
MrPackstin
Oct 25, 2017 08:09 PM
no green
Jan 9, 2016 09:22 PM
