What to do with O2 sensor??
Old Jan 23, 2009 | 09:56 AM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
No cat on car (no emissions testing here) but my O2 sensor is just hanging there, what can i do with it? (was like this when i bought it)
Old Jan 23, 2009 | 02:40 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: What to do with O2 sensor??
It's not functioning at all? Does your engine not have a computer?
Old Jan 23, 2009 | 02:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Are you sure it's an O2 sensor? There's no O2 sensor in the cat, it's in the driver side manifold.
Old Jan 23, 2009 | 02:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
On a V6 I think the O2 sensor is in the y-pipe, not the driver's side manifold. There's a hole in the pipe for the O2 sensor to screw into, on stock exhaust systems.
Old Jan 23, 2009 | 10:24 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Definitely, the O2 sensor is in the Y-pipe on the 2.8L...so, why was it just left dangling . Even if you installed the headers from Pacesetter (which I believe are the only aftermarket headers for the V-6 (other than a custom job), they have a provision for an O2 sensor - in the Y-pipe.
If the previous owner installed headers and put in a heated O2 sensor (three wires instead of two), then maybe you have some wires dangling. So, if I remember correctly, if you have a heated O2 sensor in the car, then one wire (white) goes to ground (back of the engine or firewall, for example); the black wire connects to the O2 sensor wire to the main harness and the second white wire connects to a 12V source (on when ignition is on).
Is that the case?
Old Jan 24, 2009 | 12:26 AM
Axle/Gears: stock
I'll have to check but most likely it goes into the y pipe.. I took the car to the local exhaust shop to fix the egr valve.. i mentioned to them about the O2 sensor and they just left it there.. I'll crawl under the car tomorrow and see if theres a spot in the y pipe.. theres no headers just 2.5" pipes to a flowmaster with dual 2.5" exit pipes to 3.5" tips
Old Jan 24, 2009 | 12:36 AM
Axle/Gears: stock
okay scratch that previous post.. i just crawled under there and theres a single 2.5" pipe (maybe 2.25") running from manifold to manifold and connected to that is a 3" pipe ran straight back to the flowmaster. There was no opening for an O2 sensor. It is just a single black wire with the O2 sensor attached to it. Sadly the wiring harness is such a hack job i've been strongly considering replacing it, but im trying to hold off for a few more months till i swap in the 3.4
Old Jan 24, 2009 | 08:22 AM
GTA50's Avatar
Even with the 3.4 swap, you will still need an O2 sensor. I would have the exhaust shop weld in a bung on your Y-pipe so you can put in an O2 sensor.
Having the O2 sensor should help your emissions and your driveability as well.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
