full length headers question
Old Jan 27, 2009 | 05:30 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Do any of you guys have full length headers and do they hit the floor of your cars and does it also need a Y pipe
Old Jan 27, 2009 | 05:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: full length headers question
If they're thirdgen headers they won't hit the floor, and they'll only require a Y pipe somewhere if you're planning on running single exhaust.
Old Jan 27, 2009 | 06:44 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
If you mean do they hit the ground, then the answer is yes, every speed bump and wash out the header flanges either scrape or worse.
I don't know of any pre-built y-pipes designed for our cars with long tubes, you're on your own.
TA
Old Jan 27, 2009 | 11:03 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I am gonna run a single exhaust a american thunder cat back and were would i find the y pipe the ones i am looking at are for the third gen.
Old Jan 27, 2009 | 11:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I think MAC used to make a system for Hooker Super Comps. Apart from that, anything with long tubes is going to be a custom job. If this is a street car, I'd stick with shortys.
Old Jan 28, 2009 | 09:41 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
It is for a street car so shortys would be better right
Old Jan 28, 2009 | 09:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's a lot less hassle to use shortys.
Old Jan 28, 2009 | 10:50 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
They say the flowtech ones are the same as the summit brand ones is that true for i could get the summit brand would i also need a y pipe or no
Old Jan 28, 2009 | 11:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Flowtechs aren't known for their outstanding quality. You'd be better off spending a little more money on something else.
Old Jan 29, 2009 | 02:50 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Are the headman good or what kind don't want to spend alot on them
Old Jan 29, 2009 | 02:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Hooker 2055s are a popular choice. They have the AIR tubes for emissions, and they include the Y pipe in the price, which most of the others don't.
midge54
Dec 27, 2019 04:14 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 7, 2015 09:55 PM
