header bolt torque?
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
header bolt torque?
I am installing hedman 68460 long tube headers on my 89 camaro and it has aluminum heads. What should I torque the bolts too? I think someone said 25 foot pounds? I don't have a torque wrench but may be able to borrow one. Or can I do it just by feel? Thanks.
Transmission: 4L80E/4L80E
Are your header bolts 7/16" head? If so, just tighten them with a standard combination wrench.
Or, borrow a torque wrench. I believe Auto Zone will loan you one. Of course, there are a few bolts you can't get a socket on, anyway.
Re: header bolt torque?
Ya I noticed that you couldn't get the socket on some so I prb. just do it by hand. Well the 11mm works and I can't remember the standard size. I only have standard wrenches but for the socket I used the 11mm for some reason, just can't remember the standard right now lol.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I just tighten my headers bolts to "good'n'tight" but dont overtighten them. You dont want to strip out the aluminum.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
