Hooker 2055
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: Hooker 2055
yes they are. they come with the 3" y pipe. i just installed these on my 88 t/a last saturday. i love it. woke the sleeping beast right up.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Hooker 2055
Scroll down the exhaust forum and you'll see our 2 page thread titled,"Those with hooker 2055's, come on in" LOTS of info
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Hooker 2055
Alright, thanks alot for your help guys, I'll get these then sometime soon probably, they're perfect for a swap over to a 350 too correct?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Hooker 2055
The only issue you'll have is you need the heat stove pipe on the driver's side header that goes up to the air cleaner on a TBI car, for emissions reasons. Any piece of pipe welded on there will work, its not special.
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Hooker 2055
I just got the car smogged like two months ago so i'll cross that bridge when I come across it again
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Re: Hooker 2055
Is the install on these very difficult? Do I have to jack the motor up? what needs to be removed? I'd prefer to not have to remove much
Re: Hooker 2055
check out the thread "those with hooker 2055's, come on in" i just did an install write up on it. for "MY" experience. everycar is going to install different but all the guidelines are in that thread
no green
Jan 9, 2016 09:22 PM
Chevykid810
Sep 28, 2015 12:57 PM
