Currently Flowmaster but ineed louder and more performance
Old Apr 10, 2009 | 12:34 AM
805camaro805's Avatar
Car: 91 Rs Camaro
Engine: 305 tbi
Transmission: 700 r4
I love my flowmaster dual exhaust but it does not have that muscle car sound to me. I want to know what would be the best to get on mine? The old ladies dad has a custom borla that he made when he worked for them and i may try that on. But i need something that will ****in turn heads and be ca legal.
Old Apr 10, 2009 | 12:53 AM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
Re: Currently Flowmaster but ineed louder and more performance
Well based on what you said your car needs to be Ca state legal...
i am not sure on the laws in ca, but here in colorado your exhaust has to be stock/stock replacement (i.e. muffler shop replaced your old worn out exhaust leaking pipes with factory replacements.) or its illegal
so if its the same in cali, i'd assume your borla would be illegal.
but noise violation as long as its not terribly loud you could probably get away with it, I cut the bottom of my muffler out and drove it like that for two years (the muffler bearings went south is what i told the cops )
Then i cut my cat out... that really got the cops attention.
So just be careful on how loud you go..
Old Apr 10, 2009 | 11:58 AM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
They may frown on the true duals, as third-gen cars never had those stock.
I run a single Flowmaster and I just passed CA smog, so I don't think it matters what muffler(s) are used, as long as you have them.
To be CA legal it needs to have an air-tubed cat (or cats, mine has two of them stock).
Old Apr 10, 2009 | 12:29 PM
matj1990's Avatar
Car: 83 firebird/camaro conversion
Engine: carbed 350 very mild build
Transmission: th350
Axle/Gears: 3.42 posi
the hell wit it just cut the pipe off after your headers
Old Apr 10, 2009 | 12:35 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i thought the later years had them.
Old Apr 15, 2009 | 06:35 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you are going to hate this but as of 1/1/09 you cant move the original flow of the exhaust system. if it was dual into dual cats that went under the passenger seats, that is the way it has to flow. it was a nutty system that had dual exhaust, dual cats then went into a ypipe.
once you get to the out side of the cat, you can do anything you want, provided it does not adversely effect the cat performance.
there are even rules making it harder to get an aftermarket cat - only a few are available and most require stock ones.
befoer 010109 the dmv would say dont move the exhaust but there was not really a law against it, but now there is.
you can change the cat back but that is it.
smog ****'s rule in california.
Old Apr 15, 2009 | 07:30 PM
matj1990's Avatar
Transmission: th350
glad im in ny
Old Apr 15, 2009 | 07:54 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
i miss borla here in oxnard too bad they shut down that plant, dude check my exhaust sound clip out at http://www.youtube.com/watch?v=tvvvK9QUhn4.
Old Apr 15, 2009 | 09:05 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Is CA really that strict?!?! 75% of the cars and trucks here in MN have different exhausts, straight pipes, you name it we got it! My cousin has a lifted Dodge with the cummins (oh god) and that thing is straight piped. Does Al "global warming dumb**" Gore live in California? I'll NEVER IN MY LIFE live in such a freedom sucking state. End rant.
Old Apr 16, 2009 | 10:38 AM
Car: 1990
Axle/Gears: stock
yes they can be.
the board that does air resources stuff announced that after 2010 they may outlaw black cars, too much hazard to global warming. hahahaha
Old Apr 16, 2009 | 02:36 PM
Rayvan's Avatar
Engine: LB9 225HP
Axle/Gears: 3:45BW
My car has the N10 dual cats stock. I replaced them with the Magnaflow system with larger mandrel-bent pipes. Although this setup is not CARB approved, they are similar enough to stock (pipes run in the stock locations etc.), that they didn't raise any suspicion. The car passed the visual, but a different station may have failed me if they'd asked me if the pipes had a CARB number. This was at a Smog-Only station, and my car was run on a dyno.
Old Apr 16, 2009 | 03:27 PM
rs camaro92's Avatar
Car: 1992 25th anniv. camaro rs
Engine: 3.1L V6
Axle/Gears: stock
I have heard borla before on an 86 z28 and it was music to my ears. From that day on I was hooked to borla. I need to step up and get a larger motor first before I drop a grand on my exhaust.
Old Apr 16, 2009 | 10:19 PM
Car: 1990
Axle/Gears: stock
the pipes dont need a carb number - the headers and the cats do. hooker 2055 have a carb number right on them and as of 1/1/09 you have to be able to read the numbers on the new approved cats a 5 feet, so the chp can read them without having to look to hard.
my setup is 2055 into a 3 inch y pipe then into a carb approved 3 inch single cat. from there i am still open because i dont know what im going to do.
i dont have to pass until next year so i have some time.
im looking into a single muffler by the drive shaft with one pipe over and out.
but i have carb numbers on the two things that count - the headers and the cat.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Night rider327
Oct 9, 2015 09:25 AM
