Stainless Works Headers & Custom Y-Pipe Pic
Old Apr 20, 2009 | 02:05 PM
1badbotie's Avatar
Car: 1988 IROC-Z
Engine: Fast Burn 385 Crate Engine / Accel DFI
Axle/Gears: 10 Bolt Auburn Pro / 4.10 Gears
Here's a pic of my Hawk's Stainless Works 1-3/4" header's with 3" collector. The headers have been modified to give better clearance around T-56 Slave cylinder. Mainly because I'm running the small Magnaflow spun body cats. Also to give better clearance bewteen the frame rail. The orgininal collectors were cut off and new ones were welded approx 1-1/2" to 2" shorter. Basically where the primaries begin to straighten. The headers were coated by Fireball Coaters and also the XPC coating was used on the inside to further reduce temps and prevent discolouration of the polished finish.
The Y-Pipe is also 3" and tucks up very tight, doesn't hang down any lower than the factory exhaust.
Click on Pic to englarge:
Old Apr 22, 2009 | 08:38 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Stainless Works Headers & Custom Y-Pipe Pic
looks sick
Old Apr 23, 2009 | 10:07 AM
1badbotie's Avatar
Car: 1988 IROC-Z
Stainless Works Headers & Custom Y-Pipe Install Pics
Here's a few pics of the exhaust installed
Attached Thumbnails Stainless Works Headers & Custom Y-Pipe Pic-dsc00128-1-.jpg   Stainless Works Headers & Custom Y-Pipe Pic-dsc00141-1-.jpg   Stainless Works Headers & Custom Y-Pipe Pic-dsc09998-1-.jpg
Old Apr 23, 2009 | 04:24 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: Stainless Works Headers & Custom Y-Pipe Install Pics
looks good. post an exhaust clip.
Old Apr 24, 2009 | 04:05 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
wow those look great let us know how the install goes been eyeballing these for some time now heard there was a few minor fitment problems, but hardly anyone has them so it could be just random
Old May 7, 2009 | 02:17 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
I want to know if these will fit with an LT1, and T56.
Old May 8, 2009 | 01:44 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Hey I have the same headers also they're pretty sweet and have great ground clearance to. I would like to know about your coating you put on there, it looks really good in the pic's, whats your overall opinion on it, also what they charge you for it if you dont mind me asking?
Old May 8, 2009 | 09:38 AM
1badbotie's Avatar
Car: 1988 IROC-Z
The pricing for the ceramic coat is $325 Canadian dollars for s.b.c long tube headers. $100 for the black xpc internal coating which smoothens the inside of the headers and further reduce temps. $25 a foot for ceramic on the x-pipe. They should fit the LT1 motor with T-56. You'll most likey end up having to modify them a little to clear the slave cylinder. Some guys hammer in the collector a little to clear but it would have been way to much in my case. One of the primaries would have almost been completely blocked off. That's why I decided to modify mine.
Here's a link www.fireballcoatings.com
I have another similar thread with pics of the exhaust installed in the car.
Old May 8, 2009 | 09:40 AM
1badbotie's Avatar
Car: 1988 IROC-Z
ttt
Old May 8, 2009 | 09:48 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
what is the purpose of all that spaghetti tubing just to go into a single pipe.
i could see how it might be great if it was true duals, but why bother with all that to go into a single 3 inch pipe?
don't get me wrong, it appears to be well done and thought out, you even used dual cats, nice to see you want to stay legal.
to each his own and i know people will not like my new pipes when i put them on.
yours look very good.
Old Oct 22, 2009 | 10:56 AM
RU1NER's Avatar
Can you get a pic of the ground clearance from the side please.
Old Jan 1, 2014 | 08:09 PM
irocdis's Avatar
That look Pretty close to the slave cylinder. Is that an L98 with a t-56? I have the same setup...I like the long tube header Idea...But dam that's close to the clutch slave.
Would it be that close with 2-1/2 collectors?
Old Jan 2, 2014 | 06:53 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
I'd be interested in seeing what ground clearance you have as well. Thanks.
Old Jan 5, 2014 | 11:00 AM
irocdis's Avatar
Please post the link to the similar exhaust thread. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
