Dual exhaust problems solved for aftermarket headers!!!
Old Apr 24, 2009 | 08:27 PM
goofyfuker's Avatar
Car: 85 chevy camaro iroc z28
Engine: 350 crate
Transmission: borg werner 5 speed stick
Axle/Gears: 10 bolt 373
If you want a bolt on dual exhaust kit to match up to shorty headers without breaking the bank then you need to go to summit racing...they now have a direct fit dynomax kit that wont scrape the ground and if you add thrush glasspacks the sound is excellent!!! part number is wlk-89009 dynomax dual kit 82-89 camaro for $167.95 includes all hangers and hardware to install plus gaskets FINALLY for all those people in car shops that told me dual exhaust couldnt be done on a third gen buy this kit and let em hear the dual thrush tubes lmao
Old Apr 24, 2009 | 08:43 PM
Stephen's Avatar
Car: 87 GTA
Re: Dual exhaust problems solved for aftermarket headers!!!
To save people time having to search Summit......
http://store.summitracing.com/partde...0&autoview=sku
Looks like a lot more piping than would be needed. It turns out is it duals, but both pipes run down the passenger side, then uses 2 sideways mounted mufflers, where the stock crossflow muffler sits & exits out the back, 2 tips on the drivers side. Not side exits before the rear tires.
Install .pdf on the Summit site
Old Apr 24, 2009 | 11:50 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It is also 2.25 tubing and not mandrel bent.
Old Apr 27, 2009 | 12:57 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
This kit looks to be modifiable to be both legal and side exit. A couple of dynomax inline 4 inch cats and a couple of glass packs should do it.
Old Apr 27, 2009 | 01:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That kit has been around for quite awhile. It only fits Dynomax headers directly, if you have anything else, you'll have to modify the collector connection.
It uses all of the pipes if installed as suggested. As it clearly states, the mufflers and clamps are not included (another $100 if you use the recommended mufflers).
2-1/4" and crush bends are not particularly impressive. But, at least you'll be able to claim that you have "true duals".
Old Apr 27, 2009 | 02:12 PM
bunnyfoofoo13's Avatar
so then in the long run what makes this better then say going with a custom job.
Old Apr 27, 2009 | 06:18 PM
drumminfoolz's Avatar
Car: 1985 Trans Am
Engine: 360
I would say that a custom job is better depending on what you do. There's too many turns, and it's only 2.5". That diameter would be good if you didn't plan on making big power modifications.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
gta power
Aug 13, 2015 06:15 AM
