Hedman Headers
Old May 6, 2009 | 11:17 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Hedman Headers
Im looking into getting Headman headers. I saw a long time the ones I was getting but forgot it. Im looking at a range $150 to $250. Any ideas?
Old May 7, 2009 | 01:16 AM
Superjustin13's Avatar
Re: Hedman Headers
I dont know what your question was suppose to be but.
http://store.summitracing.com/partde...part=HED-68470
http://store.summitracing.com/partde...part=HED-17478
Old May 7, 2009 | 08:02 AM
Transmission: 700r
Re: Hedman Headers
those are it. thank you
Old May 16, 2009 | 06:37 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
Re: Hedman Headers
anyone have those installed? is there a big improvement over stock manifold?
Old May 16, 2009 | 06:55 PM
S10GUY's Avatar
Car: VR6 jetta for commuting
Engine: VR6
Transmission: 5spd ZF lsd
Axle/Gears: ?
Re: Hedman Headers
yes i bought those exact pieces, i notice some diff. in the car. it revs easier and feels like theres more torque. the install is frustrating, u gotta jack up the drivers side remove some spark plugs the pass side is real easy,the y pipe isnt bad but the pass side sucks to bolt upat the header flange
Old May 16, 2009 | 11:08 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Re: Hedman Headers
i put a set of those on a friend of mines car a few years ago and just as S10GUY said there are some little things you have to do to shoehorn them in but its not bad. if i had a fairly stock car and was gona just change the exhaust id run them on mine.
Old May 17, 2009 | 03:04 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Hedman Headers
I run the exact same header, only difference is the AIR provisions.
Part number was #68481. Good luck with the car!
The AIR package was a kit I believe, and came with the Y-pipe!
Old May 17, 2009 | 09:44 AM
S10GUY's Avatar
Engine: VR6
Axle/Gears: ?
Re: Hedman Headers
the other thing i ended up doing was buying an msd univesal plug wire kit with all 90deg boots. i ended up melting some of my wires with straight boots.
Old May 20, 2009 | 08:15 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Hedman Headers
I have ran them as well.
Very hapy and plan to get a set for my 92.
I was able to install them without unbolting the motor.
Pass had to drop down from above,
Drivers had to snake it up from below.
Rousseau92maro
Feb 1, 2016 05:12 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
redformula88
Oct 14, 2015 06:08 PM
italiano67
Sep 22, 2015 08:42 AM
