dougs header leaking
Old May 23, 2009 | 11:34 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
i have dougs longtubes on my zz 383 crate motor which are d port heads. the drivers side is all good doesnt leak at all. the passenger side has a small leak on the passenger side. so the d port heads matching up to a square port header, what would be the best gasket to get. i am not going to double layer a two gaskets either. would a d port gasket better to get or a square port? who makes the best gasket too?
Old May 24, 2009 | 06:28 AM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Re: dougs header leaking
I have Dyno Dons 1 7/8 headers and do not leak. Use copper gaskets. You need to tighten the bolts after a few miles. Mine leaked at first.
Old May 25, 2009 | 02:52 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I use the d port heds and DOug's l/t headers with no problems. Use the D port gaskets for D port heads.
Old May 25, 2009 | 01:57 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
what gasket would you recommend for d-port gaskets.
z 28 jari
Sep 14, 2021 10:03 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
