How much will a new CAT change my sound?
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Hi guys
I'm thinking of replacing my cat with a high flow to open things up a little bit. I'm running straight pipes at the moment. My car isn't really loud at idle but the second you step on the gas it starts screaming. How much louder will my exhaust get with a new cat? I like not having a muffler as it's legal here and I don't care to see it blatantly under my bumper.
Thanks guys
Alex
Thanks guys
Alex
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: How much will a new CAT change my sound?
the cat wont affect sound much at all.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
If you're going from a stock cat to a high flow, it should at least be noticeably louder. Nothing crazy though.
Car: 91 formula
Engine: 350 tuned port. bolt ons
I replaced my original cat that came with my car with a highflow catco. I did notice the car being alittle louder. I do think the orginal cat my have been alittle clogged. Now i have a catco high flow cat and I have better gas milage and the car seems like it drives and preformes better.
Car: 87 GTA
Don't blast me but....
Cats are a FEDERAL requirement. Meaning, they are required in ALL 50 STATES, regardless of emisions testing or not, or what you've been told.
But for your question....
Cats can help tone down & mellow out any raspiness you might have. My car is a 2-way Magnaflow (3-way is what was put on our cars) and despite my car being "technically" illegal (no more smog pump or the air tube) my #s are so clean, they were very surprised for a 190,000 mile car!
My last test before moving to a non-emissions testing county here was:
Mar 15 2007, 02:56 PM
High Speed-2692rpm
HC 220-limit.........4-my reading
CO% 1.20-limit........0-my reading
Idle
HC 220-limit.........16-my reading
CO% 1.20-limit........0.01-my reading
High Speed-2692rpm
Idle
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
WOWSER, your car runs with like, like no pollutants coming out at all. That's crazy, I bought a 3-way, which should actually do better than your 2-way, as I also removed my smog parts and was hoping my car would pass emissions. Seems like I should be fine, since I will have replaced all tune up parts including many sensors and relays before I test her. Kind of a thanks for letting me know I shouldn't be worrying so much.
P.S. I hate the way cars sound without cats, that unnecessary rasp it gives. Of course, bigger motors make this sound better too, so...
Car: 87 GTA
If you don't have a smog pump on your car anymore, having a 3-way is pointless. The tube is for the "third way" & the lack of pump & tube going to the cat, will only throw a flag, that something is missing.
Car: 89' IROC-Z
Engine: LO3
I don't see Magnaflow messing this up...
This is what I have.
http://www.summitracing.com/parts/MPE-94109/
Car: 87 GTA
Hmmmm....I always thought 2-ways didn't have the tube & the tube was for the "third way"/3-way cats. My bad.
Thats the cat I have too, so you should be CLEAN.
I'm in a non-testing county, but cats still hafta be there visually. I could gut it, but why bother? To gain like 2 or 3 hp?
Car: 89' IROC-Z
Engine: LO3
Oh, well alrighty then
CLEAN it is.
Three-way
Since 1981, three-way catalytic converters have been used in vehicle emission control systems in North America and many other countries on roadgoing vehicles. A three-way catalytic converter has three simultaneous tasks:
Just a little wiki information.
CLEAN it is.Three-way
- Reduction of nitrogen oxides to nitrogen and oxygen: 2NOx → xO2 + N2 (THIS DOES NOT HAPPEN IN 2-WAY CONVERTERS)
- Oxidation of carbon monoxide to carbon dioxide: 2CO + O2 → 2CO2
- Oxidation of unburnt hydrocarbons (HC) to carbon dioxide and water: CxH2x+2 + 2xO2 → xCO2 + 2xH2O
Car: 87 GTA
When you test the car, come back & post up your results, or PM me with them.
I now wonder if mine is a 3-way? I bought the car from a friend who had put the cat & LS1 cat-back on, amout 2 months before I bought the car from him so......
Whoa, that's alotta good info. Thanks guys
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Car: 1990
Axle/Gears: stock
did i read this correctly? you are running straight PIPES not PIPE!
if you have true duals then you will need 2 cats.
if by PIPES you mean they split off the single pipe into two pipes then one will do.
nice place to live - no muffler required.
