Hooker 2210 question
Old Jul 23, 2009 | 02:07 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
how much clearance is there between the number 8 primary and the firewall?
Thanks-
Eric
Old Jul 23, 2009 | 02:33 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Hooker 2210 question
its fine.. it almost goes straight down first so theres not much to worry about.
Old Jul 23, 2009 | 05:46 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The tightest area is around the heater/ac box. I removed my ac and installed an ac delete. I have plenty of clearance. In fact I can do a full sparkplug change in 30 minutes.
Old Jul 23, 2009 | 05:49 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
You can see the number 8 in this pic.
Old Jul 23, 2009 | 07:59 AM
ericjon262's Avatar
I have a set of headers from a G-body project that I am going to try to use on my camaro, I also have a set of 2210's, but they would be to big for a mostly stock 305, but the G-body headers have a smaller primary, and line up almost exactly with the 2210, except for the number 8 primary, which on the other header goes backand addititonal 1.5-2 inchesdo you guys think they would fit, or would that be too far back?
also, is the slip joint on number 8 nessacary for the header install?
Old Jul 23, 2009 | 11:37 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
slip joint was very necessary even for my gutted engine bay
Old Jul 30, 2009 | 05:34 PM
F-Body Demon's Avatar
HiTech5, where did you get those valve covers!
Old Oct 15, 2009 | 10:31 PM
ericjon262's Avatar
was the engine still bolted in the car when you installed your headers?
Old Oct 18, 2009 | 06:28 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
your gonna have to jack the motor up to put those in
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
billybob6110
Sep 24, 2016 09:50 AM
formula_novice
Sep 5, 2015 03:58 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
