Trying to Figure a full Bolt in Exhaust
Old Aug 15, 2009 | 11:27 AM
crazyman3737's Avatar
Car: 1991 Trans Am GTA
Axle/Gears: Yukon 3.73 posi
So my 1991 GTA's cats finally broke apart. They both make tons of noise and its time to replace them. Well I'm planning on getting headers cats and possibly salvaging the cat back. I want to make this as easy as possible while keeping all the stock setup (dual cats, A.I.R)
The plan is to get these edelbrock headers designed to work with dual cats. http://www.summitracing.com/parts/EDL-68762/
Then Ive read tons on catco direct fit cats but I match up my car specs on summit they don't have any products that fit. I need a dual cat setup that will bolt to these headers but I'm lost... hmmm Ideas?
Than I have a Cat back that someone welded up thats a 3in pipe welded to the old cat exit. If I can cut it off at the weld and clamp it to the new exhaust I will... If not then I may buy one but I'm going to college in 2 weeks so im trying to keep cost down.
Any help on this subject would be greatly appreciated.
Old Aug 17, 2009 | 05:36 AM
Re: Trying to Figure a full Bolt in Exhaust
Uh Oh, Im in trouble if no one knows... I need a new exhaust before I go to college on the 28th :O
Old Aug 18, 2009 | 12:29 AM
firebird310's Avatar
Car: 89 FORMULA 350
Axle/Gears: 327
you should prob just go get two new cats put on at a local muffler shop prob be about 300 bucks, good luck
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
355tpipickup
Aug 19, 2015 10:02 PM
355tpipickup
Aug 13, 2015 07:35 AM
