getting high with my trans am ...
Old Aug 20, 2009 | 10:43 PM
Birdstheword's Avatar
Car: 1988 Pontiac trans am
ok , so im getting white smoke out of my tail pipes and its not oil its gasoline 91 octane to be exact , well i set my spark timing to 8* btdc like chilton says btw " chilton owns haynes" anywho my car is running real rich OR ! i am not recerculating my exhaust gas , becasuse my spark timing is right and i even tuned my throttle body unit to run a little lean since it used to dum so much gas in there . so basically eshaust is really rich and even though i have the right timing " i even advanced it more and it still rins rich " could my EGR have a major role in this problem ? btw i have to smog her by the end of this month ..... yikes!
Old Aug 21, 2009 | 12:15 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: getting high with my trans am ...
white smoke is normally coolant associated...head gasket? Any gasoline-smoke is black...
Old Aug 21, 2009 | 12:22 AM
nah , its not coolant , i just did an upper engine seal rebuild " new head gaskets and valve seals etc." and before i took my engine apart it didnt use to do that , ran fine except for the over heating , now all that is fixed except this exhaust problem . i can put my hand right in front of my exhaust pipe and gasoline will start to build up on my hand just a little bit , my car runs like this http://www.youtube.com/watch?v=vZZW_xP2iDg
Old Aug 22, 2009 | 08:28 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
I am going to assume this is tpi. check your tps and do you have an adjustable fuel pressure regulator.
Old Aug 22, 2009 | 08:37 PM
no its a throttle body , and now it even got worse , i had bypassed my coolant fan sensor so my fan could always be on but by keeping my car cool and the plugg disconnected my ecm thought my engine was still warming up eventhough it was already hott " enrichment mode at start up " so thats where i think my rich mixture is comming from , so now yesterday i was retrieving codes " a and b terminals " and i cranked my engine with the jumper cable still in place and ran it for 5 minutes then shut it off and now my car wont start , do you guys think maybe i fried my ecm ?
Old Aug 24, 2009 | 12:38 AM
after all my problems i got my car running again with no smoke
Old Aug 29, 2009 | 11:08 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
what did you do i am having the same problem with my tbi
Old Aug 29, 2009 | 11:12 PM
is it running rich or it wont start ?
Old Aug 29, 2009 | 11:33 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
it is running rich throws alot of smoke more when i step on it, at idle and when i start up the car
Old Aug 30, 2009 | 12:02 AM
well , your timing might be off " these engines like to be a couple degrees advanced 4-8 before tdc " if its not that check your spark pluggs make sure you are getting a good spark " and a strong one at that " other than that just check you whole ignition syste from pluggs , cables to your distributor cap and coil and your igniton module , or maybe you might have a dead cylinder where your not getting any spark
Old Aug 30, 2009 | 12:33 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
What should i be checking on my spark plugs, and i will do that tommorow while i am gonna replace my tranny
Old Aug 30, 2009 | 12:38 AM
the electrode on your plugg should be nice and brown at the top , make sure theres a gap between the electrode and the tip , if they are bad just replace them a set AC delcos go for 20 bux at kragens after that id that dosent work try your timing " after replacing your tranny " . just check your whole ignition system
Old Aug 30, 2009 | 12:57 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I have never done the timing what would i need or should i just take it to a shop for them to fix it
Old Aug 30, 2009 | 01:54 PM
you will need 1. a timing gun , 2. a socket wrench , 3 . an extension for your socket wrench , 4. a set of " crows feet " these are pretty cheap i think its 16 bux for a set @ autozone , its like an open end wrench but without the handle and you can mount them on your socket wrench . this is probably the best way to do it since your distributor cap will be in the way , after you get these items your set to time your engine
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Dquickshift
Aug 12, 2015 06:21 PM
