What header gaskets to get?
Old Aug 29, 2009 | 08:37 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
I am tired of changing my header gaskets. Part of it is I was using the cheap paper gaskets that worked for a while but would blow out and, the other part was i never payed attention to make sure i got the correct port size. Then I tried a soft copper and it didn't seal from the beginning. Now that I did some research I see that i need to put high temp silicone on the gasket to help it seal and I need get the correct port size. So i am going to change my gaskets the right way this time. I have Pro Topline Pro Lightning 180 cylinder heads and Headmen short tube headers from summit. What size and style ports do I need and what materiel and brand do you suggest? Thanks in advance for your help.
Old Aug 29, 2009 | 11:25 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What header gaskets to get?
I used Earl's Dead Soft gaskets and had no issues - they usually have several styles on the shelf at autozone.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
