probably a really stupid question
Old Sep 15, 2009 | 04:55 PM
bigred75's Avatar
Car: 1992 25th anniversary RS Camaro
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
what are the lines that go into the stock "headers" or whatever it is you call them. and what would i have to do with them if i get aftermarket headers.
Old Sep 15, 2009 | 05:41 PM
RU1NER's Avatar
Re: probably a really stupid question
Smog Pump, remove or purchase headers with provisions for it.
Old Sep 15, 2009 | 06:13 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
what all do i have to remove?? i dont want to leave anything open or unsealed that shouldnt be.,
Old Sep 15, 2009 | 06:22 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the only dumb/stupid question is the one that is not asked . they are part of the emissions system . there are several good articles on removal if your state does not require them . also several if you do . there are good ones on the main menu tech tips . good luck .
Old Sep 15, 2009 | 06:37 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
i couldnt find anything about what to actually take off just what will happen if i do.
Old Sep 15, 2009 | 06:54 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Your car will not be adversely affected if you take them off.
Old Sep 15, 2009 | 06:55 PM
bigred75's Avatar
Engine: 305 T.B.I.
Transmission: ????
Axle/Gears: ??????
ok but What all comes off? and what stays on??
Old Sep 15, 2009 | 07:01 PM
RU1NER's Avatar
Black box, pulley, and hoses, pretty muc everything connected.
Old Sep 15, 2009 | 11:51 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Your black AIR box comes off, the rubber hoses that connect to the black box/the one way valves connected to the metal tubes, the metal air tubes that connect to each separate pipe on the exhaust manifold, the air management tube that connects to the catalytic converter (you will need a new cat otherwise you'll have a hole in your cat where the tube used to go), and finally the smog pump.
You will need to either get a delete box for the smog pump or route a smaller belt around it.
It would be better to get a pair of Hooker 2055's
http://www.jegs.com/i/Hooker/520/2055/10002/-1
and just leave the air equipment intact. These bolt up directly.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
