smog check
Old Oct 22, 2009 | 09:43 PM
89native's Avatar
Car: 1989 firebird
Engine: 305ci efi 48k miles
smog check
want to put headers on my 89 firebird 305 what can i do or get to pass these California smog test , I'm new to California don know the laws
Old Oct 22, 2009 | 09:57 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: smog check
Make sure they come with a CARB number. Some do, some don't.
Old Oct 23, 2009 | 04:06 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: smog check
Welcome to the board!
California has the strictest emission regulations in the country. If you modify your vehicle, you must buy parts that state "50-state legal" and come with a CARB (california air resource board) exemption number. If you parts are not clearly labelled as such, you will not be allowed to pass your visual inspections.
Old Oct 23, 2009 | 04:30 PM
Formula_Wolf's Avatar
Car: 1989 Firebird Formula
Engine: 305 Road Demon 525
Transmission: 700 R4
Re: smog check
Make sure they have hook ups for your air smog system. It will hook up to your existing smog system and should be fine. To be safe, call your local emissions mechanic and ask them if thats cool.
Old Oct 25, 2009 | 03:57 PM
Almo the Pirate's Avatar
Car: 1989 iroc-z
Engine: mildly built TPI 350
Transmission: 97 T56
Axle/Gears: 3.73 posi
Re: smog check
Originally Posted by 1A Dan
...and come with a CARB (california air resource board) exemption number. .
also called an executive order, or E.O. number.
you can look those up here i believe.
http://www.arb.ca.gov/msprog/aftermk...ftermktqry.php
and heres a thread that has basically what you need to know about smog.
it wasnt a smog thread originally but it veered over in that direction.
https://www.thirdgen.org/forums/nort...third-gen.html
Old Oct 27, 2009 | 12:45 AM
89native's Avatar
Car: 1989 firebird
Re: smog check
Any suggestion on what to buy
thanks for the info
Old Oct 27, 2009 | 01:15 AM
wickedowesix's Avatar
Re: smog check
Edelbrock has some that are CARB Legal
Old Oct 27, 2009 | 11:27 AM
Car: 1989 iroc-z
Re: smog check
i have smog legal edlebrocks on mine.
the easiest way to see if they are is to look in the description. if it says "50 state legal" your good to go.
just shop around and when you find some you might like, if it doesnt specify that theyre 50 state legal, ask the manufacturer or supplier if they have an E.O. number.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
