When do headers start limiting power?
Old Dec 2, 2009 | 10:52 AM
killa66cam's Avatar
I am going to be running a 3" exhaust. When would header size start to limit my power gains? What would a 5/8, 3/4, and 7/8 diameter be good to, power wise?
Cam
Old Dec 2, 2009 | 10:36 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: When do headers start limiting power?
Depends on what's inside the engine, how many cubes, and a few other things...
Old Dec 3, 2009 | 09:54 AM
killa66cam's Avatar
Well the motor is a 305. I am going to be upgrading some parts of the motor: LT1 cam, 305 vortec heads, and a few other things. The next thing after that will be nitrous...starting with a small shot, 50 or so, but may end up being a large shot, 250+. I know that this doesn't warrant a set of big headers, but I don't want to buy another set when I go to a large shot of nitrous or change to a bigger motor and nitrous. Is there a certain horsepower number that the headers start limiting at?
Cam
Old Dec 3, 2009 | 11:54 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Not real sure I'd go a 250 shot on a stock bottom end 305, those cast pistons are a bit fragile for nitrous.... General rule on headers is the same size, or just a bit larger then the diameter of the exhaust valves.... Doubt even with the Vortec heads you would need anything bigger then 1 5/8" tubes.... Or, if you're so inclined, a set of step headers seem to work quite well with nitrous... Guess I don't have a set of dyno numbers to back it up, but I have seen a number of cars take half a tenth or so off their times with step headers.... I'm really wanting to try the step headers and merge collectors on a nitrous engine......
Old Dec 3, 2009 | 04:47 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
1 5/8 primary with a 2.5 inch y pipe to a 3 inch catback will be fine for your application. As for a 250 shot good luck, can't see you engine lasting to long. Limit it to a 100-125 shot.
Old Dec 3, 2009 | 07:54 PM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
That may be what i will wanna do so after the cat you would use a 2.5 to 3" adapter to go to the 3" intermidiate pipe and your cat back system right? I just wanna make sure because the only choices I have found is the 2.5 to 3' cat back systems from the Y pipe would that be ok? because I wanted to go with a set that had a 3" collector to a 3" y pipe I thought that may be better but you have way more knowledge on it then i do
Old Dec 3, 2009 | 08:24 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
I think you would be fine with the 1 5/8 headers.
Mark.
Old Dec 4, 2009 | 10:57 AM
killa66cam's Avatar
It won't be 250 out of the hole or anything. I am planning on using a nitrous controller, Jacobs mastermind or something similar, and probably doing a two stage setup. I am going to start at as low a shot as whatever kit I get comes with...probably 50hp jet or so. I am planning on eventually doing a 100-125 shot first stage, and then a 100-125 shot on the second stage + the first stage...or shut off the first stage, and do a 200-250 shot second stage. I am going to set it up as best I can to make it last as long as possible...but if it blows, it blows. And if it blows, I will either do a 305 built for nitrous...or a bigger v8.
I am not too concerned with a half a tenth. I just don't want to spend several hundred dollars on headers, and then have to upgrade them again.
Cam
Old Dec 4, 2009 | 11:02 AM
killa66cam's Avatar
There will be no y-pipe...maybe an h-pipe, but I doubt it. It will be headers, to mufflers, to exit in front of rear wheels. The exhaust piping will definitely 3". I was just trying to get a primary size that I wouldn't have to change. I may end up going with some used 1 5/8, since I can find them at a pretty good price...but I was looking for some 1 3/4.
I don't really care if the engine pops, to be honest. It is a toy...that is all.
Cam
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
