Is this really a V-6 Muffler on my Z28?
Old Dec 20, 2009 | 10:57 AM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Went to the muffler shop to get a quote. He said I have a V-6 muffler on my Z28. It sounds like performance exhaust to me. Hmmmm.
Can someone please solve my mystery
Attached Thumbnails Is this really a V-6 Muffler on my Z28?-camaro-005.jpg   Is this really a V-6 Muffler on my Z28?-camaro-006.jpg   Is this really a V-6 Muffler on my Z28?-camaro-004.jpg
Old Dec 20, 2009 | 01:11 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: Is this really a V-6 Muffler on my Z28?
looks like a generic crossflow muffler to me... Not sure why he thinks it's specifically for a V6.
Old Dec 20, 2009 | 10:32 PM
yoshirocks702's Avatar
Car: 1984 Chevy Camaro Z28
Engine: L69 5.0L H.O.
Transmission: T-5 5 Speed
Axle/Gears: 3.73:1 Limited Slip Posi
it is a v6 muffler, the v8 mufflers also have dual outlets but on opposite sides. still it looks pretty cool and you dont see many third gens with that type of muffler.
btw, hey Dave didn't know you were on here too :P
Old Dec 20, 2009 | 10:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
V6 mufflers had a tailpipe on each side, just like the V8's.
What counts is the inlet pipe size. Post a pic of that.
Old Dec 20, 2009 | 11:15 PM
Engine: 450HP 355
Transmission: TH350
aah, didn't look at the tailpipe pic.
yoshirocks702, i'm everywhere..
Old Dec 21, 2009 | 02:46 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Sure thing. If you need another angle I will be happy to take another pic. Thanks for the help
Old Dec 21, 2009 | 03:03 PM
five7kid's Avatar
Looks like an aftermarket V8 system, although I couldn't tell you who made it.
What were you thinking of doing/getting?
Old Dec 21, 2009 | 03:17 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
I would really like to see it with dual exhaust. I have been under the car and noticed I have two catalytic converters. I am not really sure why it was designed this way.
Reading the some of the posts above, I can imagine that the oem dual tips are created with one muffler. Funds are low right now and I am thinking that finding a used OEM muffler with dual exhuast outlets might be the best bet.
five7kid
I've seen you on here since I first found TGO. Waaaay back before I became a member. Thanks for the help. I never doubt your post as you seem to be very knowledgeable. Was glad to see you on this post
Old Dec 21, 2009 | 03:43 PM
five7kid's Avatar
Correct. Except for the '82-'83 Crossfire engines, all 3rd gen dual tailpipes came out of a single muffler.
Dual exhaust is difficult to route on our cars. Less than 2-1/2", you aren't any better off than you are with single 3" O.D., which is what most aftermarket cat backs are. Stock cat back was 2-7/8", so a well-built aftermarket 3" system would do just fine. And, they can usually be bolted up with standard hand tools if you have means of getting the car up in the air safely.
If you're willing to do the work (and I'm not particularly fond of exhaust work myself), you'd get a much better system for your $'s by buying and installing a good cat back yourself.
Old Dec 21, 2009 | 04:15 PM
Jeffs82TA's Avatar
82-83 LG-4's had the dual mufflers too.
Old Dec 22, 2009 | 01:41 PM
five7kid's Avatar
Could be. My factory '82 LG4 had an 80 series Flowmaster on it by the time I got it.
Old Dec 22, 2009 | 09:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
From the looks of the inlet pic being slightly offset (instead of centered), it appears to be a generic cross flow mounted reverse of how it should be.
The inlet is put to the outlet and the same side out is the inlet/outlet.
Might be the SoCo talking though....
TBI and v6 (3.1.. not sure about 2.8) had the same wimpy cat-back (stock) exhaust.
Old Dec 22, 2009 | 10:20 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Interesting enough, I seem to hang with the LT1's pretty good. Usually about a car length until about 110 and I start roping em back in. Maybe it's the G92 gearing and close ratio transmission. I have been wondering if there is some type of performance advantage in this exhaust. Am way off in saying that? I bet so.
Other than some super bad *** talking alarm that I removed from the car and the exhaust, it seems to be stock.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
86IROC112
Nov 27, 2015 09:54 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
cstrobel65
Sep 16, 2015 11:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
