My true dual 3" setup with X-pipe (vid inside)
Old Dec 30, 2009 | 03:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Redid my exhaust to true dual 3" all the way back. Magnaflow X pipe, some summit flex pipes, and dynomax 12" long bullets.
Gained abit of clearance back from the single 4" exhaust and the big 6" round case muffler i had under the car. I'm happy with the setup so far.
Quick video, quick revs
http://www.youtube.com/watch?v=q2Ow-FIJVj0
Old Dec 30, 2009 | 06:54 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: My true dual 3" setup with X-pipe (vid inside)
sounds and looks great.
Old Dec 30, 2009 | 07:14 PM
irocvert90's Avatar
Car: 90 chevy camaro convertible iroc
Engine: 305 tpi
Transmission: 700r4 with hurst dual gate shifter
why is there more smoke out of the one tailpipe
Old Dec 30, 2009 | 08:05 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Sounds and looks good to me. I have a question tho, does it make any difference if one exhaust pipe is longer than the other one? I noticed yours is and made me wonder about it.
Old Dec 30, 2009 | 08:53 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
sounds awesome! your car is a beast man, cant wait till my turbo setup is up and running!
Old Dec 30, 2009 | 09:43 PM
ziggy89's Avatar
Engine: 383
i watched sum of the other vids and i forgot to ask wats it look like under the hood?
any pics?
Old Dec 30, 2009 | 09:50 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Orr89RocZ--
Thanks for posting the pictures-now I have an idea of where things are going to be TIGHT!
Looks//sounds great!!
Old Dec 30, 2009 | 11:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
No idea why one pipe is more "smokey" than the other. Its cold here and thats just the way the hot exhaust reacts with the atmosphere. At first start it was even but now its clearly not so. Not sure why.
As far as length, it may matter alittle, as exhaust length has tuned effect on the cylinder scavenging. I should have had the drivers side exit on the passenger side since its the longest but oh well.
Theres plenty of room to tuck 3" under these cars in the stock cat location and down the driveshaft tunnel. Its over the axle it gets tricky. I used Vbands to connect the tail pipes to the over the axle midsection, so i can easily take down this exhaust if need be.
Old Dec 31, 2009 | 07:02 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Sounds pretty throaty. I like it.
Old Dec 31, 2009 | 12:37 PM
ziggy89's Avatar
Engine: 383
i wouldnt be to worried bout tuned exhaust lenght if you have an xpipe
kinda there to balance it out anyway
Old Dec 31, 2009 | 01:16 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Very nice. The smoke is just condensation. Looks like you did pick up some ground clearnance.
Old Dec 31, 2009 | 01:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I've could have done much better on the clearance part but i have yet to put the car on the ground to check it. From pics of my old setup i think i gained the precious few inches I wanted to gain to make this thing more streetable, as if a 9 sec car can be streetable haha.
I want to get another clip of the exhaust really warmed up, the car likes to die out when rev'd. It will rev up and once you let off, it dies. Not sure why. Fueling issues i'm sure or stall saver stuff not working. Oh well.
The turbos do help quiet things down tho but those bullets do a good job too. With straight pipes it is still pretty loud but the bullets do help give it tone and alittle less volume. I'm happy with it, from the short bits i've heard so far i think it sounds great.
Old Jan 3, 2010 | 01:51 AM
jonarotz's Avatar
Car: 91 Z28
I like the exhaust! Do you have any pics of the front pipes? I would like to see how you routed your down pipes.
Old Jan 3, 2010 | 09:36 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Sounding really nice
Old Jan 3, 2010 | 11:34 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Then downpipes go down the same path as any shorty header
Old Jan 3, 2010 | 03:15 PM
jonarotz's Avatar
Car: 91 Z28
Awesome! Thanks for the pics. I am going to make a duplicate of your system but I am going to run dual 2.5" pipes. I should be able to fit it a little tighter. I'm going to 2.5" because that is what my turbo exits are..I know someone would ask why only 2.5".
Old Jan 3, 2010 | 03:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
you'll have alot of room to get 2.5" in there.
Old Jan 5, 2010 | 08:54 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
looks nice. any pics of the rear?
Old Jan 5, 2010 | 10:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
just in the vid right now. Still undecided on the tips, i kinda like them but they need adjusted alittle.
Old Jan 6, 2010 | 02:53 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Awesome! I want to turbo my car so I can have a FMIC like yours, that thing is sexy.
Old Jan 14, 2010 | 12:55 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
looks and sounds great
Old Jan 15, 2010 | 10:02 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Sounds sweet man.
Im gonna go with a dual set up as well but with cats and the same bullet mufflers but dumped though.
Tony.
Bubbajones_ya
Jul 6, 2024 08:32 PM
86Firebird86
Dec 26, 2015 07:21 AM
Djmathis123
Sep 8, 2015 08:42 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
