odd idea here
Old Jan 2, 2010 | 01:00 AM
305forever's Avatar
Car: 98 blazer 4x4 lifted 3inches
Engine: 4.3
Transmission: auto
Axle/Gears: idk, but not a posi
odd idea here
my 84 350 camaro has no heating system, so, my plan is to run my dual exhaust pipes out toward the front seat area and have a turn down just near the front seats. since my 91 formula was stock the exhaust heated up the car pretty good, so i think this should work even better, yes no?
Old Jan 2, 2010 | 01:10 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: odd idea here
your going to fill you car with exhaust gas sitting at a light, you should try to find a heater system for your car. its going to be more expensive but its really your only "good" solution
Old Jan 2, 2010 | 01:14 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: odd idea here
Old Jan 2, 2010 | 03:43 PM
305forever's Avatar
Engine: 4.3
Transmission: auto
Re: odd idea here
ok thanks
Old Jan 2, 2010 | 04:41 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: odd idea here
ahhhh, are you serial?
Old Jan 2, 2010 | 04:47 PM
shelby7099's Avatar
Car: 1984 Camaro Z28
Engine: 350ci
Axle/Gears: 3.31 non posi = no traction
Re: odd idea here
I would say no to that. I also have an '84 and the heater was broke when I got it. Just fix it yourself or get a new one. You will learn something new and appreciate it more. It is in the 20's here in GA right now and I am glad I fixed mine!
Old Jan 2, 2010 | 11:33 PM
305forever's Avatar
Engine: 4.3
Transmission: auto
Re: odd idea here
yes i was
Old Jan 2, 2010 | 11:34 PM
305forever's Avatar
Engine: 4.3
Transmission: auto
Re: odd idea here
and i have nothing left of my heating system, all i have is the motor and steering in my engine compartment, no Power steering, no ac, no emmisions, no windshield wiper motor, nothing only bare necesities, and i dont know how the heating systems work either
Old Jan 3, 2010 | 10:42 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: odd idea here
go to a yard and get everything you need for less than 50 bucks.
hoses
blowerbox
fan
heater core
all HVAC under the dash
HVAC controls
Old Jan 3, 2010 | 05:54 PM
shelby7099's Avatar
Engine: 350ci
Re: odd idea here
Another idea I had is to use a heater like they make for old cj jeeps. You can check them out at Summit Racing and Jegs. If you have nothing left then that surely makes it more of a task, and it sounds like you are trying to keep it light, so I would check it out.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
Fronzizzle
Sep 8, 2015 12:10 PM
