View Poll Results: Which Muffler?
Borla XR-1 Race Muffler Round/Oval
20.00%
Dynomax Ultra Flo Round/Oval
10.00%
Sweet Thunder Chambered Tube
0%
Dynomax Race Bullets
20.00%
Flowmaster 40/44s
30.00%
Others(If this is your choice please post the muffler)
20.00%
Voters: 30. You may not vote on this poll
True Duals Muffler!?!
Old Feb 4, 2010 | 07:53 PM
mesterious's Avatar
Which Muffler should i get with my set up: 406SBC (AFR 210s), Big Cam, 1 3/4th LT Headers, and X pipe. Dumping the the muffler at the axle! The car will be a Weekend fun car so loudness really isnt a big problem execpt for cruising.
Old Feb 4, 2010 | 08:35 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: True Duals Muffler!?!
bullets or spiral flows, for the ultimate in loudness and flow.
Old Feb 4, 2010 | 08:56 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
something that will actually flow well.. which despite the name Flowmasters will not.
I prefer Hooker Aerochambers, excellent tone and flow. However you might have ground clearance issues depending on where you put them, maybe bullets would be a better choice.
Old Feb 5, 2010 | 07:27 PM
3833rdGen's Avatar
Car: 91 Camaro
Engine: 383
Transmission: Turbo 350
Axle/Gears: Ford 9" 4.56 gear w/spool
just put the Dynomax bullets on my 383 they sound awesome
Old Feb 5, 2010 | 11:09 PM
2002chad's Avatar
Car: 1989 GTA
Axle/Gears: 9 bolt
if you run them in duals, the way they are supposed to be run, they are not that bad.
my vote is Spintech.
Old Feb 6, 2010 | 12:15 AM
Sports Reporter's Avatar
Car: f-150 super crew
one chamber flows or even the fake flows sound great with an x pipe and flow as good as a bullet. I personally hate bullets. I like the dynomax race magnums but a one chamber flow has that unique sound. Just about every muffler shop carries the one chambers in flowmaster and flowmaster copies. They buy the copies for about $22 bucks a piece so make them give you a deal or go to another muffler shop. That motor will run good with 3" and an x pipe. You can buy the slip fit universal x pipe set up from jegs for about $90 bucks and it has enough pipe to do a 3rd gen except for the dumps.
Old Feb 6, 2010 | 07:25 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
borla or dynomax. all the others will eat a few hp.
the bullet types are going to be loud! not good for cruising. being dumped at the axle, its going to beat you do death in the car. sound like dogs barking in your ear.
your compression ratio can help or hurt the noise too.
you might look into a magnaflow muffler, or the dynatech split flows.
magnaflow has some 4x9 inch mufflers that will help with ground clearance, and the split flows have a uniquie shape that might help clear some of the floorpan area to tuck them up a lil higher.
IMO..... i would do a y pipe to single setup in the stock location.
i just got rid of my catback and dumped mine. just no room for duals without looking tacky. from behind the car.
a single setup WILL make the same power.
3 inch y pipe to a single 3.5 or 4" muffler will get the job done. promise.
Old Feb 13, 2010 | 02:49 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Classic Chambered.
Old Feb 13, 2010 | 05:39 AM
MADMAXGTA's Avatar
Car: 89 TTA
Heres a true dual set up,before and after video,enjoy.
http://www.youtube.com/watch?v=Qs7U0DRou1s
Old Feb 13, 2010 | 08:24 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
That sounds good Max. Was it hard to install?
Old Feb 13, 2010 | 08:56 PM
MADMAXGTA's Avatar
Car: 89 TTA
Not mine,Im just you tube trans am freak so i thought id share,mine sounds like the before part.
Old Feb 14, 2010 | 08:59 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
mine sounds like the before part too.
dad actully leaned over to look and c if i was watching one of my videos again lol
Old Feb 15, 2010 | 10:01 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Moroso spirals. Free flowing and loud as F#$k.
Old Feb 15, 2010 | 10:53 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
I have had both Borla and Dynomax on my car. They sound identical really. If you want longevity get Borla. The Bullets started to burn out over time. The bullets will have more clearance then the XR-1's will unless you are moving your floor. I ran 3.5inch oval for more clearence and a custom trans cross member where I had no bends in the exhaust.
Old Feb 15, 2010 | 11:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
ultraflo rounds are a bullet with more sound absorbtion but still are fairly loud. Have a good tone,i'd go in that direction. can tuck them under the car somewhat ok depending on size of pipes you intend to use.
borla XR1's are bullets with divider in the middle...a very expensive bullet. It will also be loud, i had one on my 383 for 2 days and was like no way.
Old Feb 15, 2010 | 03:25 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Doesnt really muffle all that much, but it flows great. Sounds good too. Ive had experience with flowmasters, Spiralflows, and these. And really to me it's more about the motor than it is the muffler. A hot engine is gonna sond good regardless. But went from a Flowmaster 80 to a dual 3 inch spiralflow system to a single 3.5 splitflow system and they all sound really different. But the systems they were bolted to were so different I have a hard time really doing an apples to apples comparison. If performance wasnt the main goal, I'd have a flowmaster all day long though. A cammed hot rod with flowmasters just sounds so good to me.
Old Mar 13, 2010 | 01:33 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
What kinda of muffler is that, that is a weird looking set up, perforated tube and a sound cancelation plate in teh middle? Is splitflow the brand?
Old Mar 13, 2010 | 01:38 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
im gonna put headers on then turbo header mufflers and run the pipes out the sided right in front of the rear tires.
ZEEYAA
Apr 16, 2023 08:29 PM
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
