stock 91-92 Z28 muffler centered?
Old Mar 11, 2010 | 07:42 PM
grassyflats's Avatar
I apologize in advance for my lack of certainty
I have noticed on other Z28's as well as my new/used 91 Z28
that the muffler is not perfectly centered on the automobile
it is probably not the original stock muffler
it is not centered -it is about four inches to the left if you are
standing behind the vehicle-towards the driver's side like they did not
put it completely on the exhaust pipe
I figure they just did a shotty job installing it and that it should be centered
I had a muffler installed on my RS and we centered it perfectly and
tucked it up real tight so you cant even see the tailpipes
question
were the stock mufflers centered when built at the factory?
and also
when I install my new cat-back system -will it be centered?
not a muffler guy
Old Mar 13, 2010 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: stock 91-92 Z28 muffler centered?
Here's an old pic of mine.
JamesC
Old Mar 13, 2010 | 04:40 PM
JamesC
i guess the Z muffler is not centered
Old Apr 15, 2010 | 11:28 PM
still curious...why is the 91 Z28 muffler not centered?
I saw another Z and it is the same story
It seems to me there is enough room to slide it
further onto the exhaust pipe
Did the stock muffler come like that?
e.i. 4 inches to far to the driver side
Old Apr 16, 2010 | 06:47 AM
JamesC's Avatar
As far as I know, yes. Since the tail pipes are symmetrical under the bumper, I don't see that placement is a problem. What's troubling you about it?
JamesC
Old Apr 19, 2010 | 09:51 PM
yoshirocks702's Avatar
Car: 1984 Chevy Camaro Z28
Engine: L69 5.0L H.O.
Transmission: T-5 5 Speed
Axle/Gears: 3.73:1 Limited Slip Posi
^^ my 84's muffler isnt centered either, but the tail pipes compensate for it and it looks symmetrical under the bumper.
Old Apr 22, 2010 | 12:40 PM
JamesC
I just think there is room enough to center the muffler as well as the
tailpipes so that it looks correct-being uncentered looks as if it is a mistake
my RS is centered
Old Apr 22, 2010 | 02:27 PM
JamesC's Avatar
I just think there is room enough to center the muffler as well as the tailpipes so that it looks correct-being uncentered looks as if it is a mistake my RS is centered
grassy, you've got too much time on your hands .
JamesC
Old Apr 23, 2010 | 06:33 AM
JamesC
no time to mount those firehawks,customize the van,build the RS
remodel the house and travel the world not to mention to just get laid
Old Apr 23, 2010 | 09:09 AM
Twin_Turbo's Avatar
Same here, 88 IROC-Z, not centered. It ahd a bone stock muffler with holes in it that I replaced with this one, it's in the exact same spot as befoer. The pass side rear pipe is longer from the muffler to the elbow than the other side
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
