I need serious opinions!
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
I am going to be making a new exhaust in a few weeks and I am in need of some serious opinions.
I want to avoid going over the rear axles and this leaves me with 2 options.
1. Make the pipes exit in front of the rear tires under the back of the GFX.
2. Turn downs ending at the axle.
I am strongly leaning towards the side exits more than the turn downs.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: I need serious opinions!
are you using shorties, longtubes, or manifolds?
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Why not a full length exhaust out the back?
Seems to me you've already got your mind made up.
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
man that thing is going to be LOUD!! i vote for the side exit. the turn downs before the axle makes it seem cheap and unfinished. the side exits will be extremely loud but different.
a turndown pipe will cause a lot more interior noise. i would go out to the side.
Thanks guys, thats also why I was going more towards the side exits, im pretty sure my mind is made up now
I don't follow the logic, but OK. I'd just order a set from Magnaflow, Borla, or whatever company has the product you are looking for. Then I'd have it put on the vehicle by a reputable exhaust shop if you can't do the work yourself for some reason.
I can do it myself. I guess i forgot to say that there is a money issue as well...LS1's are expensive. I have a x-pipe setting around and also a pair of 20" chambered mufflers sitting around and I plan on using the because they are still new and I plan on using them so all I will have to buy is some straight and bent pipes.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
skinny z
Oct 5, 2015 06:23 PM
