Something odd...
Car: 92 TA convertible
Engine: 5.0 TPI
Transmission: 5 speed
Axle/Gears: 3.08 posi
Something odd...
I was unbolting the stock cast iron manifolds on my 92 305 TA and discovered something I've not seen in 30-something years of working on cars. There was NO gasket between the manifolds & the heads! I checked in my Official Pontiac shop manual and it does not show gaskets on the exhaust manifolds either. I wonder, how did this EVER seal? and if I decide to re-use the manifolds, should I reassemble it the same way?
TT
TT
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Something odd...
Yep the factory manifolds didnt use gaskets. My brothers 95 Silverado was the same way. I thought someone had taken them off at some point so I put gaskets on it and it leaked. So long as the manifold isnt warped, they dont need them. If they are warped, then thats a good reason for headers.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
lol, I would use them just to save the trouble, or atleast some red rtv.
My dad said he had never installed a set. Last year we put an old 350 in a 69 chevy when we pulled the old 307. We didnt put any back on, he said it would be fine. Hasnt leaked yet.
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
hmm... when I installed my headers, not even two weeks I had an exhaust leak, I had to buy copper gaskets, never again have I had an exhaust leak... so this not using gaskets, does it also apply to headers?
Car: 88 IROC
Engine: 5.0 TPI
I'm kinda leery about not putting in gaskets, even though it came without them. I'm considering using a set of Mr Gasket copper gaskets just for my own peace of mind. What do you all think?
TT
TT
Engine: 5.1 4bbl
I see nothing wrong with it, worst that can happen is your car rejects them and you have to pull the manifolds off and take the gaskets off...
Engine: 5.0 TPI
Engine: 5.1 4bbl
well with this new found knowledge that they didn't come with gaskets from the factory, then I would too only install them with copper gaskets, that's if I were to install any in the first place...
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Most OEMs didn't use a gasket at the mechanical fuel pump either.
There was no point as the best seal is direct metal to metal.
Dante93GTZ
May 27, 2010 04:15 PM
