Headers fitment issue
I purchased my second car recently, a 88 iroc. The previous year I spent my time building a small block 350 to put in it because the iroc had no motor or transmission with it. The motor is pretty typical, a new set oh heads larger cam and new intake/carb, all of which is from edelbrocks performer rpm series. The problem I am having is that any headers I have tried that were designed for that car are to big, they hit the steering shaft and the ac box. I considered taking an inch off and snugging them up to the block but that inturn creates an issue with spart plug clearance. I want to avoid manifolds as much as possible but I can't find a set of headers to fit. Any suggestions?
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Headers fitment issue
is the 350 a 3rd gen block? I actually don't know if there's a difference ...
are you sure these headers you're using are meant for camaro/firebird third gens and not for SBC... I am using the Edelbrock TES and don't have issues with the headers coming in contact with anything...
Summit lists them as "generation 1" so I would assume them to be similar if not the same. And it could also be that the edelbrock heads are wider due to a larger combustion chamber.
Engine: 5.1 4bbl
hmmm interesting... look for dyno don here on TGO or Kevin, go through posts and see if you can find them... they both are from California, if anyone would know, they would... they seem very knowledgeable in 3rd gens...
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
if your gonna get a new set I recommend dyno dons little pricey but worth every penny
Engine: 5.1 4bbl
Car: 88 formula; 06 cobalt ss
Engine: 305 tpi; 2.4 ecotec
Transmission: WC T-5; F23
Axle/Gears: 3.45 posi; 3.84
or maybe ur motor mounts are sagging have they been replaced?
Ehh, I haven't owned the car long but there is a possibility that it could be that causing the problem. We had new brackets pit on the motor but the actual mount could be bad. If so that would fix it hitting the steering shaft...But only raise it into the ac more...
Street Lethal
Apr 30, 2019 12:14 PM
evilstuie
Feb 28, 2016 03:33 PM
kah992
Aug 19, 2015 02:55 PM
