those with dyno don headers please help
Old Apr 25, 2010 | 04:14 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Installing my dyno don headers I got the driver side in fine now I'm stuck on the passenger side. The header is hitting a tube which appears to be going to the heater core, and I can't seem to move it anywhere where it is not in the way, if anyone has any suggestions they would greatly be appreciated. Heres a picture of the problem area...sorry for the terrible pic, but it was taken with my phone
Old Apr 25, 2010 | 09:58 PM
Re: those with dyno don headers please help
well upon further inspection it seems to be hitting ac box also
Old Apr 25, 2010 | 10:19 PM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
I had that problem with a set of hooker 2055's. Thats a steel coolant line that goes to heater core. I simply removed the 2 screws that hold it in place then mocked the header up and moved the coolant line till it cleared and drilled a new hole for the screw.
Old Apr 25, 2010 | 10:23 PM
i've tried this but even with the 2 screws out it still doesn't move enough to clear header I even bent the tab for the screw, and tried pushing it under ac box, but it won't go under any further
Old Apr 25, 2010 | 10:48 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
i had the same issue with my hookers. i jacked the car up and slid the header on from underneath, as well as unbolting the bracket that holds the steel coolant line and pushing it as close to the fender as it could go. it took some fanagaling but its easier than trying from the top.
Old Apr 25, 2010 | 11:03 PM
yea I've been trying it from underneath maybe I just need to do some more persuading of the line
Old Apr 25, 2010 | 11:23 PM
trocustoms's Avatar
I forgot to mention that i cut the tab off the steel line and only used the front mounting screw. That allowed the steel line to go under the ac box and then the header cleared fine.
Old Apr 26, 2010 | 11:33 PM
thanks I'll give it a try that was gonna be my next step, but wasn't 100% sure the tube would fit under there, and really didn't feel like doing all that work, and then not having it work.
Old Apr 26, 2010 | 11:55 PM
travis401's Avatar
Car: 91 Camaro RS
its a steel line, but its hooked up on both ends by rubber hose, so it should be able to move quite a bit. if all else fails, you could always pull it out completely. but that sounds like more trouble than its worth.
Old May 3, 2010 | 11:42 PM
thanks for all the help guys got it to go under ac box it just required some very careful persuading with a hammer. All is good now
Old May 4, 2010 | 02:34 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
idk Don put mine in :P ask him
Old May 4, 2010 | 08:20 PM
Pat Hall's Avatar
I just put my 2055's in last week, and yeah that coolant pipe was DAMN close to the tubes, but it did clear just barely.
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
1984HO
Mar 19, 2021 11:59 AM
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
