92 Z MagnaFlow install
Old May 24, 2010 | 06:11 AM
cj jim's Avatar
Put my MagnaFlow in this week end and I have 5 inches of tail pipes sticking out past the bumper and had to make up a drivers side tailpipe hanger because the OEM hanger was not close, has anyone else had this condition? Just making sure I did not incorrectly installed anything.
Thanks Jim
Old May 24, 2010 | 06:34 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: 92 Z MagnaFlow install
Thanks Jim
I'd probably say you got a 4th gen exhaust or if you got a 3rd gen exhaust then the PO may have done some handy work...
Old May 24, 2010 | 06:55 AM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
My drivers side and passenger side hangers are the stock ones the brackets did have to be cut off the old pips and welded onto the new ones i had my pipes bent like the stock ones.
I believe the MagnaFlow pipes are long so you can trim them for installing exhaust tips.
Old May 24, 2010 | 08:35 AM
bcnvz28's Avatar
Car: 16 Equinox,12 Silverado,91 Z28
Engine: 3.6l, 5.3l, 305 H.O.
Transmission: 6 Spd auto, 6 Spd Auto, 4 spd Auto
Just a thought.
Is the drivers side muffler outlet towards the rear of the car? Should be to the front.
Old May 24, 2010 | 01:20 PM
Raging Sloth's Avatar
Car: 1987 iroc-z
Engine: 5.7 tpi
Just put magnaflow cat back into my 87 iroc.
looks like this underneath and at the tips
Attached Thumbnails 92 Z MagnaFlow install-262.jpg   92 Z MagnaFlow install-269.jpg
Old May 25, 2010 | 06:23 AM
cj jim's Avatar
Great info guys got it figured out with your help. Not one of my sharpest moments, I guess after fitting the fuel pump install my common sense was all used up. Thanks Jim
onefreakz
May 14, 2018 12:15 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
