Hedman header install help needed
Old Jun 22, 2010 | 03:08 PM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
I am installing a set of hedman headers and a Y pipe. The problem is, I can not fit the headers into the car. My stepdad said the engine must be pulled. Please tell me that isn't the facts of it because if so I'll just slap the manifolds back on it and say screw it for now.
Any help from people that have installed these before would be apreciated and the sooner the better because I'm in the middle of this right now and only have a helper until tomorrow night.
Old Jun 22, 2010 | 04:21 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Hedman header install help needed
Jack the car up and get em in from underneath. you shouldnt have to pull the motor. Its rare you will be able to get them in from up top.
Old Jun 22, 2010 | 04:23 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i installed my hedman headers a few months ago . # 68478 headers , # 17478 Y pipe . drivers side from above , dis-connect steering shaft . pass. side from below , remove starter . removing all spark plugs helps/recommened . you will want a custom set of plug wires . don't forget O2 sensor . good luck .
Old Jun 22, 2010 | 05:43 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
I have it figured out I think. I downloaded the directions from hedman and it says to insert them from the top. Unfortunately, I had the O2 bung welded into the wrong side of the header and it faces the engine crossmember and can not be used. I will get a plug for it and another O2 bung and have it welded in the right spot and we should be good to go from there on.
Thanks for the help.
Old Jun 22, 2010 | 08:37 PM
UNCLE TOM's Avatar
i put my O2 sensor in the Y pipe just below the connection to header . has worked fine so far . whatever you do , good luck .
Old Jul 1, 2010 | 09:49 AM
Guest
Guest
Posts: n/a
best way undo starter lay it aside pull motor mounts lift motor push oneway brace it put in one side do same to other side set down bolt up motor mounts install starter done mine were shorty headman headers they went in other then removing the starter good luck sketter
Guest
Guest
Posts: n/a
from the top in not bottom up
Old Jul 1, 2010 | 10:35 AM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
No worries, we got them in. We had to lift the drivers side of the engine about 2-3 inches for the dr. side header and the pass. side one slipped in with a little finessing. It is done and running now with no problems except for needing the chip reburned for the AIR pump, EGR and cats being gone now plus all the other mods I just did.
Here is a few pics of it completed.
Old Feb 14, 2011 | 09:34 PM
ericg83z28's Avatar
well im a lil late haha ,but i just did mine 68478 or w.e for the 1983 Z28 5.7 with the Manual trans and they were a bit tight to get in but i removed valve cover on the drivers side and the plugs and basically dropped in , the flowtechs are easier but there smaller . not a bad header but there huge!
Old Apr 17, 2011 | 12:55 AM
DoWork2day's Avatar
Car: 1989 IROC 406 SBC (2012 Fusion)
Engine: 406 Chevy-World Sportsman heads
Transmission: 700R4 B&M, Redline clutches, 2800
Axle/Gears: Australian 9 bolt,I think 3.73
I have a small block with two missing header bolts, near the firewall on the passenger side. I can't get the bolt started, my fingers can set the bolt in there, but no way to turn it once it's in there. I just can't get the bolt started.
Tips? Is there a thread that would get me some help?
Not that it matters, but the motor is a 406 with World Sportsman heads, I think it's the Hedman shorty/y pipe headers. Gonna run it at Milan Dragway on Wednesday, hoping to go mid 12's........ We'll see.
Old Apr 17, 2011 | 07:47 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Use a small head header bolt, 5/16" head or 3/8" head. Get a rubber hose 12-18" long that the bolt will fit into snugly. Place bolt in hole as best you can lining it up . Turn bolt from other end of hose...
Old Apr 17, 2011 | 08:59 AM
Guest
Guest
Posts: n/a
I have a 86 firebird with a 350 i had no problems from under the car i used small header bolts turns alittle at a time but it went in
Old Apr 22, 2011 | 08:46 AM
DJK90IrocZ's Avatar
Car: 90 Camaro IROCZ
Engine: 5.7L TPI
Transmission: Auto 4 speed
Hello....I wanted to ask anyone if they have ever installed the Hedman part 68491 setup with the stock dual cats on a 350?
Thanks!!
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
IROCZ1989
Jan 24, 2016 03:55 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
drathaar907
Aug 6, 2015 04:20 PM
