cataylic convertor gets cherry red please help
Old Jun 27, 2010 | 07:44 PM
bswanson's Avatar
car has no power ,mists ,I have changed convertor twice ,oxygen sensor ,all above sensors and fuel pump on my 1990 camero rs v-6.can anyone help????
Old Jun 27, 2010 | 07:57 PM
Tru2Chevy's Avatar
Car: 1987 Camaro
Engine: 400 sbc
Re: cataylic convertor gets cherry red please help
Getting any codes? Have you had someone hook a scanner up to it while it's running to see what's going on?
If not, get that done before you spend any more money throwing parts at it.
- Justin
Old Jun 29, 2010 | 03:31 PM
PRMRD88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 89 Vette TPI 350
Axle/Gears: 3:73
Someone help him out guys.
Old Jun 29, 2010 | 03:33 PM
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
Sounds like your running lean I had a v6 camaro think it was an 85 ran so lean it melted the manifold
Old Jun 29, 2010 | 03:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Check the muffler, did the insides of it rot out n cause an internal blockage in it.........
Old Jun 29, 2010 | 03:50 PM
Twin_Turbo's Avatar
exactly the opposite, a red hot glowing cat is caused by raw fuel burning in the cat con.
Old Jun 30, 2010 | 04:23 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Twin_Turbo is correct.
A cat gets somewhat warmer then normal if the engine runs lean.
It gets significantly warmer when unspent fuel gets into the cat.
Take out sparkplugs and see if maybe one cylinder isn´t firing. Should be the easiest to start with and could very well be the cause.
Since you explain that you changed cat twice, the cat was good.
I do not expect the problem to be caused there.
If fuel got into the cat, it´s very well possible that after you find and fix your issue you´ll have to swap the cat again though.
Old Jul 1, 2010 | 09:59 AM
Guest
Guest
Posts: n/a
my thought is your converter internally gave pushing all the stuff from inside your converter into the exhaust and now is pluging your exhaust more then likely in the muffler cut the muffler off just in front of it then start the car see what happens if it runs good again change the mufflerrepost if no change we will go from there tie up the exhaust so you can go for a ride if you get pulled over for load exhaust explain to him the problem unless he is a complette d--- h--- he will be good with that sketter
Old Jul 1, 2010 | 10:02 AM
Guest
Guest
Posts: n/a
if the exhaust flow is blocked the cat will get red red red red red hot fact
Old Jul 1, 2010 | 10:04 AM
Guest
Guest
Posts: n/a
if you dont think so stuff a potato in your tail pipe and watch it for yourself sketter
Old Jul 1, 2010 | 09:07 PM
bswanson's Avatar
thankyou for info iwill try
Linson
Oct 24, 2025 02:00 PM
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
Dragonsys
Sep 25, 2015 03:51 PM
