Knock Sensor or cooling temp sending unit?
Old Aug 8, 2010 | 01:41 PM
*327TPI*'s Avatar
Car: 1991 Camaro z28
Engine: TPI 327
Transmission: M5
I just completed a Edlebrock TES hearder installation on my 327 TPI. I took her for a test drive and shes running wrong. (hardly accelerates) I think I broke the wire clip running into the block just under the passenger side header. what is that?
Any ideas on why she's running funny?
Old Aug 8, 2010 | 08:36 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Knock Sensor or cooling temp sending unit?
under passenger side header? i believe that is the fan sensor. i cant remember for the life of me if the knock sensor is on that side...
Old Aug 9, 2010 | 07:01 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
knock sensor is in the block fan temp is in the head watch out you don't cross the connectors around since they are the same design cant remember if white is fan and blk is knock maybe some one can chime in here ok looked in my manuel knock has a blk wire and fan has a green/white wire just not sure on the connector colors though
Old Aug 9, 2010 | 11:59 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Easy way to tell which wire is which - turn key on, and ground them - if the fan switch wire is grounded, the fan will come on - nothing will happen if you ground the knock sensor wire.
Old Aug 9, 2010 | 02:06 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
The knock sensor is the white wire.
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
