poppping sounds!
Old Sep 13, 2010 | 01:01 PM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
poppping sounds!
I have changed all the spark plugs and wires and it still making popping sounds. Some one told me I needed a new cat. Converter. I have dual cats. and one has been changed before and the other is still the orginal one. Popping sounds are not loud but you can hear it when you get behide the exhaust or I can feel it when I'm at a red light. Do I need a new Cat Converter?
Old Sep 13, 2010 | 01:19 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: poppping sounds!
Does it choke and stumble when you stomp on it or backfire when you let off the throttle? Set an SES light? If so, could be the cat. Happened with a newer BMW that I own, bad cat was the cause.
Old Sep 13, 2010 | 01:37 PM
pestrada38's Avatar
My light used to turn on when I get on the freeway. It would always turn on the freeways. Sometimes with I let the pedal off I hear the pops. But my service light doesn't turn on any more.
Old Sep 13, 2010 | 01:46 PM
Wadebryant's Avatar
Did the bulb burn out? lol
The ses light usually lights for egr or cat fail reasons. If it runs poorly under heavy throttle, when passing, or when getting up to traffic speed in a hurry and all other systems are functioning, I'd suspect that the exhaust system is choking. Likewise, when it de-cellerates if you have light backfire igniting the unburned fuel in the exhaust. Those were similar symptoms with my beamer.
Have you taken it to an exhaust shop for analysis?
Old Sep 18, 2010 | 04:35 PM
pestrada38's Avatar
i fixed my cat it does feel a little better but the little popping sounds are still there. more when i turn on my a/c. the car starts to shake with popping soubds on a red light ir wgen i come to a redlight. can it be one of my fuel injectors that is stuck open?
Old Sep 18, 2010 | 06:25 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Small holes in the exhaust can cause a popping sound, especially before the cat.
Old Sep 20, 2010 | 10:57 PM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
valve springs getting weak?
Old Sep 21, 2010 | 10:17 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
How big is your exhaust tubing? Also does it make poping noises when your on the highway going 70 and then let go of the gas? It could be your diverter valve. It controls your EGR... exhaust gas recirculation valve. That can cause poping noises if that goes bad. Look into that.
Old Sep 22, 2010 | 01:34 AM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
just an idea, take an hammer or just hit agaist your muffler and if you hear stuff moving around, your baffles fell out and you need an new muffler.
Old Sep 22, 2010 | 04:29 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Have you checked the timing? So your ses light doesnt come on at all? It should light up when you turn the key to the on position. It should come on when you try to retrieve codes.
Old Sep 22, 2010 | 04:44 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Running lean....
Old Sep 22, 2010 | 09:25 AM
pestrada38's Avatar
i dove it all day yesterday and the weather was hot. my service light turned on and when i finally got home it smelled like gasoline from the engine.
Old Sep 23, 2010 | 11:32 AM
Car: 1989 IROC-Z
Find out what code its throwing?
Old Sep 23, 2010 | 05:04 PM
J91's Avatar
J91
If you have a fuel leak, you are running lean, check the plug color, find the leak and fix it. Popping from exhaust can be caused by lean burning conditions...
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
