hooker 2055 headers and plug ???
i just bought a 86 iroc and im ordering some 2055 hooker headers .. i also am going to order some msd 8.5 plug wires and new spark plugs .. will the msd wires and stock ac plugs work with these headers ??? or are the plugs to long ? i read somewhere on here about accell shorty plugs for some headers ..
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: hooker 2055 headers and plug ???
The shorties make it a lot easier to swap the plugs with the headers installed. Make sure the wire set you get has 90* plug ends of course.
I had a set of those Hookers over a decade ago, and with regular length Delco plugs I recall not being able to get them out with the headers on. Granted, I was 17 at the time, so I may have just been being dumb. lol
Ironic that you ask though actually because I'm about to do the exact install on my IROC. Not sure how soon (probably this weekend), but I'll let you know what I see.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Car: 92 Firebird
I just checked on summit and mine are 2460HKR, quite a bit different than the 2055. The 2055 seem to be everyone's favorite..
The only one i know of that would be better would have been the SLP Tri-Y design found on the Firehawk, but those have been discontinued.
The 2460's are 1 5/8th, but a thicker wall tubing so the ID is more restrictive.
I love my 2055's, but I'll be going with Long Tubes in the future. Way more power potential. At one point the TransAm was my sole car, so I needed the ground clearance (lived in an area with very large curbs and the like).
But now, I could care less if I scrape, I want that extra power. Its not my DD anymore, i can afford to lose some ground clearance.
This tool helps a LOT when working with the plugs around these headers:
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
I run Autolite AR25's they are shorter than delcos but not as short as the accels. I can get most of them out I think the center 1's are gonna be hard.
evilstuie
Feb 28, 2016 03:33 PM
