lo3 headers on 350TBI??
Old Nov 17, 2010 | 09:58 AM
88chevycamaro's Avatar
Car: 1988,1989 camaro
Engine: sbc 350 TBI
Transmission: 5 speed, th350 w/shift kit
Axle/Gears: 3:27
im looking to get some headers on my camaro and im not sure what do get for brand and what would fit? i think the motor is a 350TBI but i can get to the serial number without removing the motor because its realy close to the firewall plus i dont have much time to work on the car i dont want to remove the motor...next time i might remove the vavle cover and try to look for the serial number again but just in case i was wondering if headers of an lo3 would fit my 350?
Old Nov 17, 2010 | 11:26 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: lo3 headers on 350TBI??
any thirdgen 305 headers will fit a 350; they use the same ports and bolt pattern. no need for casting or serial numbers
Old Nov 17, 2010 | 03:04 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
right on! thanks for the reply!....what would you recomend for best sound and performance?
Old Nov 17, 2010 | 03:27 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Just be aware of what size the headers are... some that are designed specifically for 305s might use 1.5" tubes, and those could limit the benefits on a 350 compared to a 1 5/8" pipe.
But, most are generally 1 5/8" anyway.
Old Nov 19, 2010 | 05:59 AM
Engine: sbc 350 TBI
Axle/Gears: 3:27
i see....so what brand would you recomend for best sound and performance?
Old Nov 19, 2010 | 08:32 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Honestly you can't go wrong with hooker 2460s if you have smog removed. If you dont the 2055 is a good choice AND comes with a ypipe. But Dyno Dons are by far the more superior headers from what i've read. You can never go wrong with big 1 3/4" headers.
Old Nov 20, 2010 | 10:51 AM
Engine: sbc 350 TBI
Axle/Gears: 3:27
about smog....ive been looking around i cant cant even figure out what it is?...im new here so i dont know very much...plus where im from inspections arent strict so ive never heard of it?
Old Nov 20, 2010 | 03:42 PM
Stangski09's Avatar
Briefly explained, it is called A.I.R. and it basically just pumps air into the manifolds while the car is warming up. It really clears up the engine bay when you remove it, but if you need to smog legal i'd suggest keeping it. It's easy to get off; but if you had to put it back on it would def not be fun.
The main parts are:
- Air Pump
- Diverter Valve
- Air tubes into manifolds
- Connecting tubes
- Cat tube
And the cat tube and connecting tube are bolted onto the ground bolts that are located on the rear of the head. And some cars have a rubber connecting tube ,where my car had a metal line (which was not fun to remove). The rubber one would be much easier.
Old Nov 20, 2010 | 08:27 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
ok i see was wondering what those lines were...is it the ones that look like brake lines?...where im from i dont need it to pass inspection so i can remove it
Old Nov 24, 2010 | 06:24 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
i think ive made my decision im going to get 2460hkr headers and a super 10 series muffler cat back for the exhaust.....what should i get for piping sizes??....i was thinking 2.5'' all the way with 3'' tips?
Old Nov 26, 2010 | 04:58 AM
rs coastie's Avatar
Car: 91 camaro rs
Engine: tbi 305
If your retaining the oringinal style exhaust setup i'd go with a 3inch intermediate pipe into dual 2.5 out back.
Old Nov 26, 2010 | 02:47 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
why smaller out back?
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
