o2 sensor mount
Old Mar 8, 2011 | 01:34 PM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
o2 sensor mount
does it matter where the o2 sensor is mounted as far as on the headers collector or can it be mounted off the collector on the pipes?
Old Mar 8, 2011 | 02:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: o2 sensor mount
Man id double check but I believe its 18-24 inches from the motor is the sweet spot.
But I do know the old trick was to use cheap spray paint and paint a good section if it and pipe then start it up. where the end spot where the paint burns off is where they put it. Right at the end of the still hot zone but not to close / HOT.
Old Mar 8, 2011 | 02:11 PM
Car: 91 camaro
Engine: LS3
Re: o2 sensor mount
I just put on long tube headers and I mounted the sensors right after tw collector but now the ECM won't get out of open loop and I think it's because of the sensors
Old Mar 8, 2011 | 02:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: o2 sensor mount
Well they don't work right till they get hot, could be to far with long tubes, get a heated O2 maybe
Old Mar 8, 2011 | 04:30 PM
Car: 91 camaro
Engine: LS3
Re: o2 sensor mount
Yea it's lt1 has heated o2 I think they are too far down or they went bad
Old Mar 8, 2011 | 08:59 PM
torque_is_good's Avatar
Re: o2 sensor mount
how many wires? the 93's had single wire O2's (un heated)
Old Mar 9, 2011 | 08:51 AM
Car: 91 camaro
Engine: LS3
Re: o2 sensor mount
4 wires...I think they just took a crap..I'm gonna replace them today and see what happens
Old Mar 9, 2011 | 02:21 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: o2 sensor mount
W/ long tubes, you will probably a need heated 02 sensor. Also, if you are running AIR, you will need to make sure the 02 sensor and the inlet pipe for the AIR (into the cat) are as far apart as possible. Otherwise, at low speed, backflow/reversion AIR will make the 02 sensor think the engine is running super lean, and dump fuel into it.
Old Mar 9, 2011 | 02:50 PM
Car: 91 camaro
Engine: LS3
Re: o2 sensor mount
No AIR,no cat just long tubes straight pipes I'm in Florida no emissions checks here...but at work right now I'm just gonna change them and see what happens it's dumping way too much gas right now and I have a 95 lt1 set up came with heated o2's thanks for the info though definetly cone in handy
Frozer!!!
Jan 19, 2024 04:55 PM
Wife'sCar
Sep 5, 2015 08:58 AM
Bert87
Aug 23, 2015 03:50 PM
timonator
Aug 11, 2015 09:56 PM
