any tips on how to remove the exhaust manifolds?
Old Mar 17, 2011 | 09:40 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
im getting ready for the big 2.8 to 3.4 engine swap and i need to use my 2.8 manifolds so i need help on how to remove the manifolds on both the engines so opinions please.
Old Mar 17, 2011 | 10:08 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: any tips on how to remove the exhaust manifolds?
soak with a good penetrating oil . do this several times for several days . soak the bolt heads & the surfaces that the manifolds mate to the heads . this will help removal , chase the threads in the heads . clean well the threads on the bolts you will re-use . clean well the threads in the head & don't break any bolts on removal . good luck .
Old Mar 17, 2011 | 11:36 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Get a broken and stripped bolt remover kit it will probably happen and save time when it does so u don't have to stop work and run to the parts store for tools.. if not u can always return it
Old Mar 18, 2011 | 07:39 AM
Engine: L31 350
well my question is this. some people heat the bolts up to make the removal easier so on my 2.8 since it still runs. can i start the car and let the car heat those bolts up its self so when i take the bolts out it will be easier?
Old Mar 20, 2011 | 12:46 AM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
If you're doing an engine swap, unbolting the y-pipe from
the manifolds will probably be easier.
Then dealing with the rust issues of removing the manifolds will be
much easier when the engine is in the workshop.
Old Mar 20, 2011 | 10:58 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
heating the bolts makes them expand, thus they are larger in the bolt holes and harder to remove. heating the bolt holds (ie the heads) without heating the bolts would be the way to go, but this is kinda pointless in reality. just use PB Blaster several times a day for a day before hand, then they should come out no problem. given that the motor has spent it's whole life heating and cooling and reheating, exhaust manifold bolts aren't usually a big issue.
Old Mar 21, 2011 | 07:33 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
I just removed my manifolds today. I woke up and sprayed pb blaster on all of the bolts 3 hours later all of the bolts came out with zero problems. The bolts I didn't spray that connect to the y pipe I snapped one. Fml ha ha I'm not sure if I can get the stud off the manifold and drop a bolt in or not.
Old Mar 24, 2011 | 06:07 PM
Pocket's Avatar
Car: 91 Trans Am
A V6 is small enough that leaving the manifolds attached wont hinder removal. Much easier to mess with the engine out of the car
Old Mar 24, 2011 | 06:47 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
^^^ good to know.
but what i did was for about a week or two, i would spray PB Blaster all over the bolts 2-3 times a day. They came out like they were brand new and not one broke.
Old Apr 17, 2011 | 08:01 PM
Engine: L31 350
i picked up seaform deep creep so that should work i hope, also im just gonna leave the manifolds on but i cant find the damn bolts for the y pipe!!
Old May 21, 2014 | 01:25 PM
JDHawke's Avatar
I need to replace the gaskets in the manifolds on my 2.8, does spraying the bolts with PB blaster work good?
Old May 21, 2014 | 02:27 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Yes, do it a few days in a row a few times a day then go at it.
Old May 21, 2014 | 09:42 PM
JDHawke's Avatar
Alright thanks
transaero
Aug 31, 2015 01:14 AM
theshackle
Aug 22, 2015 06:52 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
3rdgenparts
Aug 8, 2015 07:09 PM
