header install
Old Mar 22, 2011 | 11:57 AM
91bluez's Avatar
header install
hey guys.....im going to be installing a set of hooker 2460 headers on my 91 z28 305tpi.....its got an ads superchip and thats about it....will i be able to delete my a.i.r. and my cat with no complacations?.....codes popping up etc etc
Old Mar 24, 2011 | 07:43 PM
91bluez's Avatar
Re: header install
allllrighty then.....no help once again
Old Mar 24, 2011 | 08:00 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: header install
allllrighty then , did you try a search ??? once again that can help . once again it has been covered many , many times . once again , good luck .
Old Mar 24, 2011 | 08:14 PM
hairysox33's Avatar
Re: header install
*Insert sarcastic reply*
Mod: "Thread Closed"
There, I sped it up....
Old Mar 24, 2011 | 08:33 PM
UNCLE TOM's Avatar
Re: header install
no sarcasm was intended , just a lighthearted attempt/request to use search before asking a question . a question that has been asked many times . but , i must compliment you on your concern . good luck .
Old Mar 24, 2011 | 10:01 PM
hairysox33's Avatar
Re: header install
Not directed at you
Old Mar 27, 2011 | 12:59 PM
91bluez's Avatar
Re: header install
thanks for the replys.......i know about the search thing.....i just wanted a simple answer.....if i wanted to spend an hour searching out info then there is no sence to this board when i could go on the net and SEARCH there......but hey...we are car guys ...every man for himself right!
have a great day!
Old Mar 27, 2011 | 01:25 PM
hairysox33's Avatar
Re: header install
The threads chosen were quick, there are MANY more, all somewhat revolving around the same question. I believe getting a code is hit or miss according to some replies in the linked threads. I had a check engine light after running no cat, and removing the A.I.R. components installing a sent of Hedmens on my old car (L03).The TPI car on the other hand I currently have, has no exhaust hooked up after the Headers, and I have no lights/codes whenever I ran it.Its not every man for himself, nobody chimed in, and you didn't seem "light hearted".I searched for 2 minutes and found the mentioned links.
Header Info:
https://www.thirdgen.org/forums/exha...e-headers.html
https://www.thirdgen.org/forums/exha...r-install.html
Cats/A.I.R. Info:
https://www.thirdgen.org/forums/tpi/...-pump-air.html
https://www.thirdgen.org/forums/tpi/...at-delete.html
https://www.thirdgen.org/forums/exha...mporarily.html
https://www.thirdgen.org/forums/exha...ml#post4294963
https://www.thirdgen.org/forums/tech...eting-i-r.html
https://www.thirdgen.org/forums/tech...smog-pump.html
have a great day!
Old Mar 27, 2011 | 05:51 PM
91bluez's Avatar
Re: header install
Thank you for taking the time to help me!...i have tried searchs on differant occasions and find myself (sometimes) going in circles so i find it a little less agravating to just ask a question.
Old Mar 27, 2011 | 06:22 PM
91bluez's Avatar
Re: header install
yup...all questions answerd!!!!!
thanks again
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
