donut gasket replacments?
Old Apr 5, 2011 | 09:48 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
how much do you guys think an exhaust shop would charge me to change my donut gaskets on my 86 2.8? could i do it myself? where could i get the gaskets if i could?
Old Apr 7, 2011 | 11:07 AM
Engine: L31 350
Re: donut gasket replacments?
anyone?
Old Apr 7, 2011 | 07:28 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I thought you had to do an engine swap anyway? Just put them in while swapping..
Old Apr 7, 2011 | 07:34 PM
Engine: L31 350
debating on swap, or rebuild, idk where they are or how to repalce them though
Old Apr 7, 2011 | 07:43 PM
They're between the exhaust manifold, and y-pipe.
I had to replace one on a 91 3.1 before, its really not that bad.
Old Apr 7, 2011 | 09:19 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
X2. After your engine cools, soak the everliving pee out of bolts with PB blaster the night before. Then hit them again a while before you start. Even if they weren't put on with Chuck Norris torque, anything exhaust related tends to feel like it when it comes to removal after thousands of miles.
Old Apr 7, 2011 | 11:27 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Shoot them with PB/liquid wrench and then tap em with a wrench or something. It helps. Pretty easy to do once the bolts are out. Another hand helps when putting it back together, one holds the exhaust, the other bolts.
Old Apr 8, 2011 | 10:32 AM
Engine: L31 350
the gaskets just drop in dont they? also where can i pick up a set of them?
Old Apr 8, 2011 | 01:53 PM
I bought mine at autozone, but that was years ago now..
Looks like it's a special order part from there:
http://www.autozone.com/autozone/par...mString=search
Just call around to the local parts stores.
Old Apr 8, 2011 | 02:56 PM
Car: 82,83,99 T/As
Engine: 350,350,383
I meant shoot/tap the bolts. The gaskets are drop in and bolt.
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
