Header Collector gasket?
Old May 19, 2011 | 09:09 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Engine: 383 Mini ram
Axle/Gears: borg warner 9 bolt
Quick Question!
i have an 87 iroc with the l98 5.7.
I have an exhaust leak on the drivers side exhaust manifold right where the y-pipe meets it.
Is there a gasket for this? Ive read that there is no gasket on the stock exhaust manifold collector, but im not sure.
If not, then im thinking i might have a busted flange.
Thanks. !
Old May 19, 2011 | 10:42 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Header Collector gasket?
I am not sure whether thier is one stock or not. But I am assuming the factory would put one there. At your local parts store they often call this the manifold flange gasket. check it out.
Old May 21, 2011 | 06:56 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
If its ball and socket no. Otherwise yes you should have one.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
