smog pump delete??
Old Jun 6, 2011 | 01:51 PM
88chevycamaro's Avatar
Car: 1988,1989 camaro
Engine: sbc 350 TBI
Transmission: 5 speed, th350 w/shift kit
Axle/Gears: 3:27
smog pump delete??
hey i started to take the manifolds off my 88 camaro to put shorty headers...its a 350TBI and i realized that the smog pump has to go....i tried to figure out how to take it off but some help would be realy nice!!
Old Jun 6, 2011 | 09:57 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: smog pump delete??
You have to remove the pulley off the pump to access the bolts that hold the pump on the bracket. Just 3 bolts that hold the pulley on, 2 bolts that hold the pump on to the bracket then from the back side just need to take the 2 small bolts off that bolt the air inj valve on and that's all you need to do to take the pump out its really simple
Old Jun 7, 2011 | 10:34 AM
Engine: sbc 350 TBI
Axle/Gears: 3:27
dosent sound to bad! ill have a look this week end
thanks
Old Jun 7, 2011 | 11:19 AM
FueledSoul's Avatar
Your welcome, Here is an explode view just for fun. like i said its real simple
Old Jun 7, 2011 | 12:45 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
where did you get those pics?
Old Jun 7, 2011 | 11:51 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
looks like he has some parts manual for it or something, its a pretty easy task. you should be able to do it no problem once you take the pulley off. and a tip. loosen the bolts before you take the belt off
Old Jun 16, 2011 | 07:05 PM
galletti's Avatar
Car: 1988 IROC Convertible
I have an 88 TPI and would like to remove the smog pump. What part number belt would I need?
Old Jun 18, 2011 | 12:54 AM
FueledSoul's Avatar
try to search i bet you'll find the numbers, or try the TBI board
Old Jun 18, 2011 | 07:34 AM
galletti's Avatar
Yeah, I shoul've deleted this message. I posted overzealously. One search and two minutes later I had my answer. Sorry.
Old Jun 27, 2011 | 06:44 PM
1badride's Avatar
Car: 1988 RS Camaro
Engine: 305 TBI
Axle/Gears: Stock
Not to hijack the thread but What size npt plugs are required for the manifolds the plug the holes after removing the air injection reactor pipe?
Old Jun 28, 2011 | 06:22 AM
Engine: sbc 350 TBI
Axle/Gears: 3:27
not sure but if i were you i would get some headers
Old Jun 28, 2011 | 08:08 AM
1badride's Avatar
Car: 1988 RS Camaro
Engine: 305 TBI
Axle/Gears: Stock
That is the plan but currently I just want to remove the Smog pump and related items to clean up the engine compartment. (Gotta walk before you run type thing)
Old Jun 28, 2011 | 11:09 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
1/4" pipe plugs. any hardware store should have them. just did this myself. got tired of the raspy noise headers make under my hood.
Old Jun 29, 2011 | 12:12 AM
1badride's Avatar
Car: 1988 RS Camaro
Engine: 305 TBI
Axle/Gears: Stock
Thanks for the 411
Old Jun 29, 2011 | 12:14 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The air pump is an emissions control device, and it is illegal and a violation of FEDERAL law to remove it on a street car in the United States. Even if your state doesnt do emissions testing, its still illegal to remove an emissions device.
It has to be said to keep thirdgen.org from getting into trouble.
By the way, my car is making 377 horsepower to the wheels, and I still have all emissions devices hooked up and working, and it passes California's tough smog test.
Old Jun 29, 2011 | 08:51 PM
1badride's Avatar
Car: 1988 RS Camaro
Engine: 305 TBI
Axle/Gears: Stock
Kevin that is only half true from 1995 to 1996 Chevrolet released a tsb stating you could remove emissions / due to (Water in AIR Pump) issues they where having. I know I have one and the emissions is GONE..........Saved some weight and runs better
Technical - Water in AIR Pump and/or DTC P0410, P0412, P0415, P0416, P0100, P0101, P0102 or DTC 48 (AIR System Disable Procedure) #01-06-04-011
1995-1996 Chevrolet Caprice, Impala SS
4.3L or 5.7L Engine (VINs W, P -- RPOs L99, LT1)
Old Jun 30, 2011 | 02:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Doesn't appear to apply to 3rd gens.
Old Aug 1, 2011 | 10:20 AM
Engine: sbc 350 TBI
Axle/Gears: 3:27
im almost done taking the smog epuipment off and i was thinking what damage could it do if i leave the pump & pulley on for now & run it like that for a while....the piping is all off & i just need to put some new headers on
Old Jul 23, 2014 | 08:51 AM
petrarca0425's Avatar
Car: !986 Iroc-z
Engine: 305 corroborated
Transmission: T5 (manual)
Did anybody reply to this post because it is exactly what I was looking to do? Or did you ever just take the tubes off and leave the pump/belt?
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
