HELP w oil in exhaust PLEASE!!
Old Jun 21, 2011 | 02:51 PM
cz28coptzer327's Avatar
Car: 84 camaro Z28
Transmission: borg warner T5
i recently replaced the rings in my motor but i had alot of blow by from them being bad.. its a brand new flowmaster exhaust.. all stainless.. anyone know how i can get the majority of the oil out of my exhaust system?
Old Jun 21, 2011 | 06:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: HELP w oil in exhaust PLEASE!!
Drive - it'll burn off.
Old Jun 21, 2011 | 06:49 PM
hairysox33's Avatar
True... But is there any chance your rings haven't seated correctly?
Old Jun 21, 2011 | 10:21 PM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
If your not sure about rings add tranny fluid to each cylinder then drive it 2 birds 1 stone
Old Jun 21, 2011 | 10:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Trans fluid is NOT recomended 2 be used in cyls or on cyl walls. Call your ring manufacturers and see what they recomend.
Yeah just drive car an oil will burn out. Carry a fire extinguisher, just incase..
Old Jun 21, 2011 | 11:28 PM
camaroinoh's Avatar
Car: 84 z28
Trans fluid cleans and seats the rings better then any high dollar mixture they probly tell ya to buy and no it doesnt harm anything
Old Jun 22, 2011 | 01:30 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
inless there is a valve seal leaking into the exhaust
Old Jun 22, 2011 | 07:50 PM
Car: 84 camaro Z28
i just put new valve seals in so its not that... and i pout marvel mystery oil in the cylinders for 24 hours then drained it then ran it.. its not smoking bad anymore.. but before i fixed it it blew alot of oil into my pipes... just wanted to get it out so itll stop.. but ill just run it..
Old Jun 22, 2011 | 08:27 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
this might be a great excuse to put miles on your car unless you replace your exhaust theres gonnna be left over oil some where... it think putting miles on the car are the only soulution
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
carattini
Sep 10, 2015 07:46 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
