yes true dual question
Old Jul 14, 2011 | 04:07 PM
crash17's Avatar
Car: 92 camaro
first i am sorry to those who hate rewriting on the forums, as i am sure its been covered. second i have google this and didn't really find anything useful.
so here i go; what i have. 92 camaro with a carburetor 350 with hedmen headers, 700r4, 10 bolt, stock ride height. right now i have a true dual but it is a horribly close to the passenger floor (actually heats the floor) and it dumps right before the rear end. i would like the set up where it runs near the drive shaft and dumps at the rear similar to stock position. so any diy kits or a good affordable shop near ferndale michigan.
Old Jul 15, 2011 | 07:25 AM
crash17's Avatar
Car: 92 camaro
Re: yes true dual question
Wow no one? Man not any luck. Well if yall don't know I will post what I find on my own.
Old Jul 15, 2011 | 08:15 AM
andy74's Avatar
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
if you search this board there are tons of threads on duals, i have a similar set up to yours,but everything ive found in kit form is a y pipe to single to a dual out let muffler-i actually took one off my old parts car,and brought the y pipe to a local shop this morning,he is goint to call me with a estimate to make a new one(rusty) fyi, he said he would build a true dual set up for 350,labor included,but it seems to be the general opinion that a good y pipe,and 3 inch cat back is more than enough for most street cars-good luck!
Old Jul 15, 2011 | 08:41 AM
crash17's Avatar
Car: 92 camaro
Thank you. Now I actually don't have a cat. It was long gone before I even got the car. So I guess I am not even sure a shop will touch it. But again thanks for a confirmation.
Old Jul 15, 2011 | 11:49 AM
andy74's Avatar
there is a heat shield that should be between the cat and the floor,if its missing that will help a lot with the heat
Old Jul 15, 2011 | 12:28 PM
crash17's Avatar
Car: 92 camaro
I don't have the stock exhaust
Old Jul 15, 2011 | 01:05 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Here is my build, Custom dual set up from headers back to the bumper. Since this post Ive added two magniflow oval mufflers on each side of the trunk well.
As for the floor heating up get your self a hold of the factory heat shield where the cat was. Its not on the cat! Its on the floor pan. Its a large piece of sheet metal that is spaced a bit from the floor pan to reflect the heat.
https://www.thirdgen.org/forums/exha...wered-3rd.html
Old Jul 15, 2011 | 08:07 PM
92Z's Avatar
92Z
Any pics of the two magniflow oval mufflers on each side of the trunk well? Any part numbers?
Old Jul 17, 2011 | 08:58 AM
Transmission: t-56
Now the exhuast is not symetrical since the trunk is not, but i did not care. Im going to try and work on a sound clip.
[IMG]yes true dual question-begvg.jpg[/IMG]
[IMG]yes true dual question-umk8o.jpg[/IMG]
[IMG]yes true dual question-uciwi.jpg[/IMG]
[/IMG]
[IMG]yes true dual question-yxtbx.jpg[/IMG]
[IMG]yes true dual question-x5ohz.jpg[/IMG]
Old May 26, 2017 | 09:35 PM
k3cars's Avatar
woow, brog warner rearend.....
Is there more shots?
Thanks man
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
